E type ( XK-E ) 1961 - 1975
new temp sensor installed-gage is pegged in the red zone?
Old Jun 4, 2017 | 02:32 PM
racerxf12004's Avatar
Default new temp sensor installed-gage is pegged in the red zone?
68 xke. Temp gage stopped working. Installed new threaded pin style temp sensor. After 2 minutes gage is pegged in the red zone. Car is not overheating. Coolant level is fine. Any help?
Old Jun 5, 2017 | 07:55 AM
billb44's Avatar
First, verify no wires broke or fell off. If you have a meter, check the voltage at the sender, it should read several volts. 0 indicates no connection to the gage, 10 volts no connection to ground.
I have been through several sensors on my 68 and have seen a variation of 25C between them. Suggest you place the new sensor in a pot of boiling water, connected with clip leads, along with a kitchen thermometer to measure the inaccuracy. Use the old sender as a plug. Or just ask your supplier for a new one.
Bill
