E type ( XK-E ) 1961 - 1975
Raven, reaction plate remove
Old Oct 23, 2015 | 12:38 PM
Reginald Adrian Hankin's Avatar
Default Raven, reaction plate remove
want to take out engine and box, any pointers on removing reaction plate with 4 bolts without stripping threads, reggie...........
Old Oct 28, 2015 | 04:20 PM
Jagrick's Avatar
The jaguar manual covers this-I can cut and paste or scan info for you if you don't have
Old Dec 29, 2016 | 06:34 PM
felinecat's Avatar
Default reaction plate removal
The high torque pressure from the torsion bars is held by the Reaction plate, so it is very hard to take out the two bolts on each side that go through the plate.
Jack up the front, so the wheels hang down.
The manuals tell you to remove one of the bolts and then drive a 3/8" rod about 8" long in its place. Now remove the other bolt and drive a rod in it's place.
Repete this process on the other side, now take out the two big 1/2" bolts that go through the frame rail and the reaction plate. Drive out these bolts and replace them with grade 8 new ones. Now if you are going to rebuild the front suspension, remove the lower wishbone mounts and drop the spindles free.
This will make those 3/8" rods you put in the reaction plate easy to tap out. BUT,
If you are not doing any suspension work then carefully tap the top 3/8" rod so it just clears the torque reaction plate, leave enough of it in the bracket to hold things in place. Now tap the lower one out, each side and remove the plate with lots of prying.
leadfoot4
Jan 1, 2024 09:17 AM
GrahamJagX
May 16, 2019 04:44 PM
NCamie
Oct 31, 2015 10:38 AM
deelli
Oct 22, 2015 11:09 PM
deelli
Oct 22, 2015 11:05 PM
