E type ( XK-E ) 1961 - 1975
Runs great at first, then not..
Old Jul 18, 2022 | 09:33 AM
Bruce W's Avatar
Default Runs great at first, then not..
1970 OTS that has been converted to triple SU’s, normally very reliable. Recently it will run fine for the first 15 minutes or so on the road, then behave as if it is running on only 4 or 5 cylinders. Sounds like a lawnmower and I’d describe it as “missing”. I suspect that it’s probably more fuel related than electrical. I have added oil to each of the carbs, but it’s possible that I’m not using the correct weight, or something other than what was previously used. Any thoughts?
(This is my first posting, but I come here weekly to see the common problems and advice - great group!)
Old Jul 18, 2022 | 04:08 PM
Bob_S's Avatar
I would check the ignition system first. Try replacing your condenser and or coil. The fuel system gets blamed for a lot of ignition problems.
cheers,
Bob S
Jag of Michigan
Old Jul 19, 2022 | 04:18 AM
dibbyandco's Avatar
Yeah, doesn't sound like fuel to me. Some component is starting to fail when warm. Rotor arm (even new "red" ones) are a common source of this type of problem. Or crack in dizzie cap. What ignition system are you on? Try the common electrical parts first. One at a time, to eliminate causes. Plug leads, HT lead can all cause this.
Old Jul 25, 2022 | 10:25 AM
Bruce W's Avatar
Thank you for the responses gentlemen. I’ll start looking at the ignition components.
Old Aug 15, 2022 | 08:21 AM
Bruce W's Avatar
Turned out to be the magnetic pickup in the Pertronix distributor…
Old Aug 15, 2022 | 02:18 PM
David84XJ6's Avatar
What was the failure in the magnetic pickup?
Old Aug 22, 2022 | 10:09 AM
Bruce W's Avatar
David, the diagnosis was beyond my capabilities. I had it towed to my Jaguar guy who diagnosed it, did a complete tune-up and said “the problem turned out to be the magnetic pickup”. I’ll be seeing him this week with an XJS V12 I just bought, I’ll ask for more details because I’m curious too.
gtcoastie
Mar 30, 2021 08:37 PM
sandyandherman
May 24, 2018 01:32 AM
andyXJR
Feb 18, 2017 04:34 PM
Darrenmb
Nov 21, 2014 04:33 PM
cliff328
Jun 24, 2010 09:39 AM
