E type ( XK-E ) 1961 - 1975
Timing pointer
Old Apr 5, 2020 | 02:23 PM
Terry S Martin's Avatar
Default Timing pointer
Does anybody have dimensions for the timing pointer for a 1969 S2. 4.2 . I do not have the time to order one and wait for delivery. Post to Canada seems to be 10 days.
I need dimensions for the bolt center distance. Or simply some info as to the symmetry of the point to the bolt centers.
I am supposed to be in my Tune up shop on Thursday and would like to make the guy a pointer to expedite the process
Old Apr 6, 2020 | 02:20 PM
David84XJ6's Avatar
Terry
The holes are 1 inch apart and the pointer is 1/2 inch above the center-line of the holes. The pointer is about 1-1/4" long
You can bend a piece of coat hanger wire with needle nose pliers to make temp pointer.
David
Old Apr 6, 2020 | 03:34 PM
Thanks David,
I will make one up from sheet metal, I figured it would be symmetrical, it will have to be final positioned at TDC on #6 I presume.
Old Apr 6, 2020 | 07:49 PM
David84XJ6's Avatar
Yes forward cylinder # 6 TDC
Richard_gib
Oct 21, 2017 01:47 PM
adenshillito
Jun 22, 2015 06:44 AM
mctb
Mar 31, 2014 08:30 AM
Time-Pilot
Nov 3, 2013 07:19 PM
kdross
Sep 9, 2010 08:08 AM
