E type ( XK-E ) 1961 - 1975
Wire behind radio
Old Jun 11, 2022 | 10:19 PM
boat54's Avatar
Default Wire behind radio
I found this wire behind the radio in my 1974 XKE OTS with a 4 speed. Any idea where it goes?
Old Jun 11, 2022 | 11:35 PM
lrgridley's Avatar
Just guessing but perhaps used for the rear window defogger on the coupes, so not used on the OTS.
Old Jun 16, 2022 | 09:35 AM
billb44's Avatar
Here is my guess. The label on the radio says negative polarity which synonymous with positive ground. But at his stage, all etypes were negative ground. Perhaps your radio is a retrofit which would have needed some rewiring. The wire may be 12v from the ignition switch accessory position used to power the original radio and cannot be used now. Alternately, it may the original ground wire which also cannot be used. If this guess is true, the chassis of your radio may be 12v and needs to be isolated from ground. You should have this checked in case it was not done properly.
Old Jun 17, 2022 | 07:29 AM
Daytona's Avatar
it is hard to determine what that wire is without knowing a few things.
What color is the wire? Have you checked it with a voltmeter to determine if it has power to it with Ignition Off, on, on accessory?
Bill.
Old Jun 17, 2022 | 11:48 AM
nileseh's Avatar
I stopped worrying about disconnected wires in that rats nest back there. There are lots of wires that are intended for alternate configurations. I think the rear window defog is a good bet, I know its a 16 or 14 gauge black wire.
But, more importantly, what does "OTS" stand for? I have a '74 series 3 roadster, but I don't think I've seen that designation.
Old Jun 17, 2022 | 08:01 PM
Daytona's Avatar
OTS = Open Two Seater. Roadster.
jpipe
Nov 19, 2023 01:12 PM
KameronJaguarxj8
Apr 29, 2020 08:37 PM
Camerenxj6
Oct 4, 2018 04:04 PM
treborefir
May 28, 2018 07:28 PM
jsv737
Feb 27, 2012 10:23 AM
