E type ( XK-E ) 1961 - 1975
Wiring route
Old Sep 5, 2014 | 01:01 PM
Johncspadaro's Avatar
Default Wiring route
Working on resto, can't figure how to route wiring in trunk! And maybe connections to tail lighting
Old Sep 5, 2014 | 06:30 PM
Mr. Barry's Avatar
What year is your car?
Edward
Old Sep 5, 2014 | 07:49 PM
bump for help??
Old Sep 5, 2014 | 08:43 PM
69 xk e type 4.2 convertible , disassembled car 8 years ago, forgot the proper routing and hook up of wire harness, want to make sure it's correct before I install gas tank! Looking for diagram or detailed photos
Old Sep 5, 2014 | 08:45 PM
Hopefully one of the E type gurus will be able to help John
Old Dec 31, 2014 | 05:30 PM
Jagrick's Avatar
Do you still need routing. I am tearing down a 68 OTS as I type
Old Apr 8, 2015 | 07:47 PM
AHudson's Avatar
I'll answer in the OP's absence : YES! i need help on this topic. We've stripped the trunk on my S1 OTS for a full rebuild, new tank, wiring etc. Have photos of disassembly showing wiring that was 'probably' incorrect, would love photos of
a. where the loom comes in
b. how it routes to lights, tank, other
ANY pics or diagrams would be very helpful!
Old Apr 8, 2015 | 09:58 PM
vrracing's Avatar
Maybe this will help...
http://www.coolcatcorp.com/faqs/XKE_Series_2_Wiring.pdf
There are a batch of wires running down both sides of the sills but I'm not sure you can tell which go down the left and which the right from this diagram.
Old Apr 9, 2015 | 10:59 AM
Jagrick's Avatar
Default wiring
I am actually working on line drawings of frames, trunk, etc showing routing, what bundles go where etc. I also have photos, my 68 OTS is in rough shape but pretty much untouched for wire routing, etc, so I will gather some stuff and post here-Rick
Old Apr 10, 2015 | 03:28 PM
AHudson's Avatar
Thank you for that! We have a good schematic, but scratching our heads over the routing.
Old Apr 10, 2015 | 03:29 PM
AHudson's Avatar
YESSIREEE! That would be fantastic! The photos of the wiring routes would be incredible to have. I imagine you'll need them in your future as well!
Scoured the web to no avail, though it's probably out there 'somewhere'. So, I am perched and ready to see anything you come up with. Thank you so much.
Old Apr 11, 2015 | 11:50 AM
Jagrick's Avatar
Default Wiring
Hopefully will be out there tomorrow, just bringing the shop out of hibernation and started a resto of a 1960 frogeye sprite for my wife.
Old Apr 12, 2015 | 10:34 PM
Jagrick's Avatar
now into side panels
Wire bundle from passenger compartment through grommet. Same routing on other side
branches off to fuel sender and continues downtto left tail light and back up light
Old Apr 12, 2015 | 10:37 PM
Jagrick's Avatar
left side still see drain and wires to tail light and to reverse light: This is left side of car
left side bundle coming through trunk wall into passenger compartment
Old Apr 12, 2015 | 10:41 PM
Jagrick's Avatar
bundle on left side now passes along inside of sill in depression to front of car
Right side you see bundle and boot lid release cable
Old Apr 12, 2015 | 10:45 PM
Jagrick's Avatar
right side routing, basically the same but carries wires for fuel pump and right tail light
reverse light wiring
wiring past fuel pump to right tail light
Jagrick's Avatar
If you need some more let me know
Old Apr 13, 2015 | 11:12 AM
AHudson's Avatar
That is like over-the-top fantastic! THANK YOU A MILLION! I owe you at least two warm beers for that. I'm sure the guys at the shop will be glad to see those. Thank you Rick and to Jaguar forum.
Old Apr 14, 2015 | 05:09 PM
AHudson's Avatar
Jagrick, just spoke to the restoration guys and BINGO! Your photos are what they needed. My offer just went up to 3 warm beers! Truly appreciate it, we owe you. Thanks again.
Old Jun 17, 2015 | 01:43 PM
Colfod's Avatar
Am doing the same to my 71 series 2 roadster and these pictures are a Godsend. I'll give you a six pack of cold beer!
