E type ( XK-E ) 1961 - 1975
Won’t Start!
Old Dec 24, 2017 | 06:38 PM
1970WillowGreen's Avatar
Default Won’t Start!
pulled her into the paint booth and was fooling with the fan fuse and now she won’t start at all. She’s not getting spark. We replaced the ignition relay, new points, new coil and now new ignition relay harness. Nothing has worked. Anyone have any ideas? 1970 4.2
Old Dec 25, 2017 | 04:16 PM
Fraser Mitchell's Avatar
When did the car last run, before or after you changed all that electrical stuff ?
Old Dec 25, 2017 | 11:52 PM
Yeah it ran perfectly and then we noticed the fans weren’t working so we messed with that and it hasn’t started since
Old Dec 27, 2017 | 09:21 PM
billb44's Avatar
Use a volt meter. With the ignition on you should have 12 volts at the coil +terminal. Assuming that is OK, check the coil -terminal several times after clicking the starter. Should sometimes read 0 other times +12. If not there is trouble with the points, the ground or the hot lead. If that is OK, be suspicious of the connection between the rotor and distributor cap and check that the rotor is firmly seated. Good luck.
Old Dec 28, 2017 | 01:39 PM
alfred's Avatar
Mine had a similar issue after switching to electronic ignition. Turned out to be the choke cable had snapped and that prevented it starting or even firing on one cylinder. No spark - try another coil - they can pooch without any warning.
Old Dec 28, 2017 | 02:13 PM
enderle's Avatar
Had a similar issue after doing some rewiring, turned out I'd disconnected the wire to the coil. Ran a new wire and installed a new relay and it actually starts better now.
Old Dec 29, 2017 | 11:06 AM
Thanks for the info guys. Been a little suspicious of the choke, we’ve re-wired the ignition relay to the coil and still nothing. We’ll try your guys suggestions next
Old Dec 29, 2017 | 11:09 AM
The choke cable being broken didn’t allow spark?
Old Dec 29, 2017 | 03:18 PM
alfred's Avatar
Naw, sorry for the confusion, It had spark at the plugs, but had no interest in starting or "farting". I did have no spark another time, and had to figure things out when I replaced the ignition switch and moved one wire to the wrong terminal.
Old Dec 31, 2017 | 08:56 AM
Mr. Barry's Avatar
When you switch on the key, do you hear the fuel pump tick?
Disconnect the fuel line at the filter bowl, and see if the pump will pump gas into a jar....
If you have spark and you have fuel, it will start....
Next , remove the air cleaners , and look to see if the choke butterflies are operating....Still no start? Spray some starting fluid in the carbs, and stand back when you crank....
Just my 2 cents
Edward
avt007
Nov 1, 2015 06:45 PM
Bcxman
Aug 3, 2015 09:53 PM
GT42R
Jul 6, 2012 06:44 PM
monkamah
Aug 29, 2008 06:23 AM
