F-Pace (X761) / C-X17 2016 - Onwards
Cold engine during extended driving
Old Feb 6, 2026 | 04:30 AM
roman_mg's Avatar
Default Cold engine during extended driving
Jaguar F-Pace 20d AWD Prestige, 132 kW.
Friends, I'm solving a cold engine problem on my wife's car. Even on a longer drive (distance approx. 40 km, speed 90 km/h) the coolant temperature on the clock is just above the blue value.
If I increase the speed to approx. 160 km/h then the engine starts to warm up, but the indicator rises to approx. 1/4 of the range, and is well below the "warmed up" engine, roughly in the middle of the range.
If I slow down back to 90 km/h, the indicator returns almost to the blue field, meaning the coolant temperature drops almost to the initial value of a cold engine.
I'm looking for the cause, I've ruled out a completely bad thermostat, but it could be stuck. Maybe.
The question is where to start, and how many thermostats are in the engine, I assume about 2.
Or go some other way?
Thanks Roman
Old Feb 6, 2026 | 09:51 AM
RoverJoe's Avatar
Community Influencer
Yep, thermostat is sticking open or your coolant temp sensor is failing, I would assume the t-stat. Left side of the engine right on the block.
Alan Wrench
Oct 18, 2025 02:48 AM
jya
Jul 9, 2024 12:47 AM
justinhill
Oct 17, 2023 10:39 PM
harvest14
Nov 28, 2017 02:43 PM
1964Daimler
Jan 11, 2017 02:44 AM
