FPace startup memory items intermittent
Wondering if others have experienced intermittent issues with memory functions on startup.
iE: start vehicle and the following may, or may not work.
*tilt wheel position (sometimes stays in up position - not saved memory position).
*Rear camera stays on after changing from reverse to drive gear.
*Sync for driver passenger temp always reverts to not being synced.
*And the occasional other weird stuff...
Peter
Peter
+1 to failing or partially discharged battery. The first thing to eliminate before looking for more obscure possible causes.
We ask all members to include VEHICLE DETAILS in their forum Signature for good reason. If this a a 2023 you just drove out of the dealership recently then it is likely to be an electronics fault. If it's a 2017 with the original battery then it's almost certain to be the battery. One thing is certain - it's not the 2009 Vanden Plas in your profile.
Yup, it's not the VDP. As the thread title indicates, it's an FPace. Howver, I didn't indicste in this thread that it is a 2017.
If there was an issue with the battery I would think it would appear more outwardly in terms of the vehicle starting. This has happened since I purchased the vehicle in December. It feels more like wonky electronics. However, I could be wrong. Peter
Peter,
You will get weird electronic behaviour on a modern Jaguar long before you get starting issues. They are all VERY sensitive to battery condition and state of charge. As I wrote in post #3, I'd eliminate this before looking for more complex (and inevitably more expensive) possibilities.
Peter,
Last Jaguar for me.
Peter
hemlock
F-Pace (X761) / C-X17
Mar 15, 2016 10:12 PM
