Help please to Identify Part Number for Air Deflector
Hi,
I'm trying to find the part number for the front air deflectors on my 2023 SVR, I originally found it but being that it was so easy, I never gave it a second thought until I tried again but I can only track down the F-Pace standard piece and not the SVR version.
I ordered the standard unit but there is considerable difference.
Looking at the parts listing, I can't seem to find it as it is not illustrated.
So, I have been still looking for this part and have had quite an interesting journey. I pulled the right-side piece off to find an identification/part number but it was no help.
I have found the non-SVR but for the life on me, I cannot find the SVR model.
I did find that the item can be called an Insert, Deflector, Stone Deflector or Air Deflector.
Will keep looking and will update once I get this all sorted out.
I believe you need #9 on this page, without your VIN I am not sure which one is the right one for your car, but the before/after in the last columns should help you with that.
Thank you RoverJoe. I was able to get help from JimboV8 from another forum and thank you for finding the catalog entry as this confirms the recommendation. I looked for the parts T4A44459, T4A44460 but ran into another hurdle and will be trying again with a local dealership hopefully tomorrow now that I'm back home for a few days. I could see this kind of problem for my 2010 XF but for a 2023, it's a bit surprising.
After looking at none conventual sites other than Jaguar, I was able to find purchase options but no images to confirm prior to purchasing.
It very well may have an updated part #, I don't have the right access to the parts system to check that, just basic catalog browsing on my side. I'm in technical, not parts sadly.
Hi RoverJoe, I am very much appreciative for your help and very thankful. I have a strong suspicion that these are the part numbers. I never had the chance to look into this today and the parts department will be closed for the weekend, I will check into this on Monday and having these numbers will significant assist.
