High pitch noise coming from climate system
My SVR has a super high pitched noise coming from the climate system when the fan is running in the higher settings. It is like a "test tone" on a hearing test.
Is is definitely from the blower/vents as it does not matter if the radio is on or off. I am not the only one hearing it.
Anybody else have this in there F-Pace?
I am a little confused, once you replaced the filter, the high pitch noise went away or is it still there after the change?
If it is now gone, what filter did you use? Factory or aftermarket replacement?
This repeated itself twice before I avoided that situation and after replacing the filter last time, it never came back. It is was like a whistle sort of.
