F-Pace (X761) / C-X17 2016 - Onwards
Screw the crankshaft to the connecting rods.
Old Mar 8, 2024 | 04:52 AM
Nogosaki's Avatar
Default Screw the crankshaft to the connecting rods.
I have Jaguar f pace 2018 y 2.0 gasoline.
I don't know if my English is that bad, I bought the instructions and I can't find how to screw the cranshaft to the connecting rod. Thank you for your help. The engine is already waiting to be assembled and all I need is this information.
I only found this but it applies to 3.0 diesel.
Old Mar 9, 2024 | 02:53 AM
Welcome to the forums Nogosaki,
I've moved your post from X-Type for to F-Pace forum and deleted the other one from F-Type forum.
Are you asking for the procedure for bolting the connecting rods to the crankshaft?
Old Mar 9, 2024 | 02:59 AM
Nogosaki's Avatar
I am mainly interested in what force should be used (Nm) to tighten the bolts. I am familiar with the procedure. Thank you for your answer and help.
Old Mar 9, 2024 | 04:10 AM
The bolts are torqued to the specified number in Nm and then rotated (tightened) by a further 125 degrees.
Old Mar 9, 2024 | 05:25 AM
Nogosaki's Avatar
Yes but this specification what I found is for different engine. I can't find anything about gasoline even though I have the service manual.
Old Mar 9, 2024 | 02:49 PM
I have the TOPIx Workshop Manual for my F-Pace with the 2.0 litre (petrol) Ingenium engine but the connecting road and main bearing torque specifications are not included.
My XK 5.0 has a similar Workshop Manual with limited details on engine specifications. I do have the separate JLR publication for the 5.0 litre engine which includes the torque specifications for the connecting rods and main bearings:
I think you will have to find the equivalent engine document for the F-Pace for these specifications. It is likely to be available for download from TOPIx but you will need an account and a subscription for this.
User 070620
Apr 13, 2018 08:55 AM
User 070620
Apr 11, 2018 01:35 AM
daboss085
Nov 1, 2012 05:13 PM
CGMMOTORSPORTS
Jan 14, 2008 11:53 PM
