0-60 times, stated and actual
Old May 21, 2016 | 07:42 AM
Dylan Bigg's Avatar
Default 0-60 times, stated and actual
Hi lads,
I'm doing homework on the notion of the SVR...and some questions:
There is a lot (as in more than the expected "quite a bit" of disparity among all the 0-60 and 1/4 times of the F models it seems. I've not been able to find a definitive list of the best recorded R and R AWD. Of course Jag states 4.2 for both...but I've seen the RWD down to 3.6 somewhere I believe..?
If so, I wonder what that means for the SVR? If they have a habit of being half a second too conservative, are we looking at a 3 second car? Doesn't seem likely, even with the power bump, re-calibrated tranny and maximum specced weight savings?
Keen to hear some thoughts!
cheers.
Old May 21, 2016 | 09:00 AM
Stohlen's Avatar
I don't expect the few pounds of weight loss and extra 25 horsepower to have a huge difference over the AWD R. Since the AWD R can do it in 3.4, I'd guess you'd be looking at 3.3 seconds. There are better cars if your focus is solely on acceleration.
Old May 21, 2016 | 11:15 AM
DPelletier's Avatar
jaguars estimates seem very conservative. Best V8S time I've seen is 3.4 and a couple 3.6's. The R doesn't seem a bunch quicker (the 40hp has to contend with another 170 lbs and some additional driveline loss although traction is obviously better) but probably a tenth or two and it's undoubtably more consistent. the SVR should be a tiny bit quicker but I doubt it can do a 3.0 stock. ....my money is on the P7 for quickest...if the SVR can beat one 0-60 due to the AWD, I don't think it could in the quarter..
2 cents,
Dave
Old May 21, 2016 | 01:01 PM
Arne's Avatar
The best I have seen documented on a 15 rwd R is 0-100 km/h in 3.7 sec. I would guess that is close to 0-60 mph in 3.5-3.6 sec.
It has a lot to with tires and traction. The 15 R is a bit lighter than the SVR and even more so than the awd R, but traction is a challenge when you start from standstill.
Old May 21, 2016 | 01:59 PM
Dremorg's Avatar
Car and Driver has the '15'R at 3.5 to 60mph.
Old May 21, 2016 | 06:20 PM
Dylan Bigg's Avatar
Thanks guys. So seems that 3.5/3.4 is indeed the realistic minimum for the AWD R? IN that case, I agree that a 3.3 MIGHT be possible on a good day with the SVR specced correctly. Cheers!
Old May 21, 2016 | 07:24 PM
Stohlen's Avatar
I know for a fact it will do 3.4, I've done it before. But the only advantage the SVR has is the weight factor. It doesn't have any extra torque, so the horsepower gain is minimal on the top end.
Old May 21, 2016 | 10:45 PM
psb1013's Avatar
Motor Trend tested the 2016 F-Type R AWD doing 0-60 in a blistering 3.3 sec!
2016 Jaguar F-Type R Coupe First Test Review - Motor Trend
Old May 21, 2016 | 11:25 PM
Dylan Bigg's Avatar
That's even better than I thought.
Old May 22, 2016 | 05:33 AM
polarisnavyxj's Avatar
Default Drove a Tesla Ludicrous last weekend.....
Just sayin'
Old May 22, 2016 | 09:18 PM
Dylan Bigg's Avatar
Oh there are much faster things out there in the price bracket, some of which I'm cross-shopping. Still interesting to know though!
Old May 23, 2016 | 07:49 AM
Schwabe's Avatar
"around" 3.5 seconds is the limit of heavy V8 front engine, high torque, RWD cars no matter the HP ... it is all about a perfect launch. You need something like an Ariel Atom to beat that. More likely than not the SVR is not a smidgen faster than an R in any circumstances ... the R may get very close to 200mph without a limiter ... it is just a question of a long enough, flat straight away because of the 8 gears ... the rest is marketing ... my S has 600+ bhp by the way ...
and here an V8S
Old May 23, 2016 | 08:10 AM
Dylan Bigg's Avatar
2015 Jaguar F-Type Coupe R vs 2014 Porsche 911 50th Anniversary Edition - Head 2 Head Ep. 55 - YouTube
and here an V8S
2014 Jaguar F-Type V8 S: The Meanest and Loudest Jag in the Jamboree! - Ignition Episode 92 - YouTube
The z06 is the same formula, and does well south of 3.0.
Old May 23, 2016 | 09:51 AM
Schwabe's Avatar
not in stock form ... that is GTR and 911 turbo territory ... everything else is hot air ...
and that is on cup tires ... versus street P zeros on the Jags. I have no doubt the Z06 is faster but not below 3 seconds in a repeatable fashion. Not saying you cannot have "a" run below but then you also have to check the timing method ...
Old May 23, 2016 | 10:00 AM
Foosh's Avatar
I don't think it's well south of 3.0, but it is faster everywhere it really counts. In fairness, the Z06 (and regular Corvettes) are not exactly a classic front powertrain configuration. The engine is set well back of the front wheels, and the transmission is mounted just in front of the rear wheels.
Lastly, it has a substantial weight advantage with the C7 coming in at about 400 lbs. lighter and the C6 800 lbs. lighter than F-Type V8s.
Old May 23, 2016 | 05:32 PM
Dylan Bigg's Avatar
GMs official number is 2.9:
The 2015 Corvette Z06 Hits 0-60 In 2.95 Seconds, Is Stupid Fast
A couple of mags have managedwith the auto. Fastest Laps calls it 3 flat:
Chevrolet Corvette Z06 C7 laptimes, specs, performance data - FastestLaps.com
Also, regarding the R35 comparison video, note that Randy has since retested it with the proper aero, and it's beaten the R35 Nismo. It is in fact now the 4th fastest production car ever around Laguna Seca, which is pretty hilarious!
Viper ACR, P1, 918....Vette.
Old May 23, 2016 | 05:41 PM
Foosh's Avatar
OK then, I'll give you "barely" south but not "well." I am a big Z06 fan, and my last was a C6 Z06. And as I said, it is definitely one of the fastest production cars in the world where it counts on the track.
Old May 23, 2016 | 06:02 PM
Dylan Bigg's Avatar
I'll pay that! "well" was a step too far. Anyway, it IS the same basic formula, and IS definitely faster in a straight line. That's the only point I wanted to make...I'm no Corvette apologist lol.
Old May 23, 2016 | 06:18 PM
Foosh's Avatar
Really, what else has the engine mounted in front and the transmission in the rear? My definition of the basic formula is front engine/front trannie. That's why I called it a "hybrid" configuration. It's also considerably faster around any road course, not just in straight lines.
Old May 25, 2016 | 06:43 PM
355spider's Avatar
0-60 times are irrelevant in cars with more than 500hp. Just ask any of the GTRs I destroyed in my ZR1. I'm sure as I put car lengths on them they felt secure in the idea they were faster 0-60. It's all traction limited off the line. Quarter mile trap speed and 0-180 tells the story.
