2016 Trouble filling gas tank
Old Sep 27, 2016 | 07:24 PM
hawianjim's Avatar
Default 2016 Trouble filling gas tank
Every time I fill up the nozzle keeps tripping off.The attendant has to turn the hose nozzle strait up for it to fill properly.Anyone else experiencing this problem? Thanks in advance
Old Sep 27, 2016 | 07:39 PM
Unhingd's Avatar
Look for all the threads on gas filler necks. Take your car back to the dealer and ask them to replace it under warranty. It's a known issue.
Old Sep 27, 2016 | 08:58 PM
tberg's Avatar
hawianjim
Although I don't have an F-type, but an XKR, I experience this on a regular basis. It's infuriating! However, I have noticed that it only happens at one brand of gas station, in my area, USA Gasoline Stations. It does not happen at Shell, Valero, Mobil, etc. Obviously, it's not the gas but apparently the nozzles they use are much more sensitive to back pressure than the other brands. In your case, think about where this happens, and I would bet it happens at a particular brand.
There have been issues with this with the F-type, but it happens on many other models as well.
Old Sep 28, 2016 | 05:35 AM
Van1's Avatar
This is a known problem with many Jaguar vehicles. I have the same issue sometimes with my XF. Like others I've found that certain pumps are never a problem and others always are. I've learned that if you don't put the nozzle in too far sometimes that solves the problem.
Old Sep 28, 2016 | 10:57 AM
buickfunnycar.com's Avatar
The "fix" didn't correct the issue for me and then I had to deal with fingerprints, footprints and smudges all over my white car left from the service department so rather than get stressed, I just fuel up at a Chevron station 20 miles from my house, it works 100% correctly there every time and I see all kinds of high-end exotics there as well so evidently I'm not the only one who has discovered this station.
Lousy greasy service techs are the same reason why I ignore the stereo buzzing issues.
Revere
Nov 6, 2024 07:54 AM
Andreas Schmieg
May 8, 2021 06:16 PM
StellaLunaGardens
Sep 27, 2016 02:12 PM
Scotlad
Sep 26, 2016 07:50 PM
StellaLunaGardens
Sep 21, 2016 09:51 PM
