2017 F-Type R Tuned +100 HP
  #61
Old 03-21-2017, 11:57 AM
JVIII's Avatar
Originally Posted by Stuart@VelocityAP
It's not your plugs. If you did 7 pulls on the dyno then you are most likely hitting catalyst over-temp protection mode and the car is either dumping fuel, or pulling timing to get the EGT's down.
These cars are extremely sensitive to cat temps, even 2 pulls in consecutive order without adequate time in between will tip them into protection mode. You need a lot of airflow (I don't see a big fan there, but I'm sure you have something set up there?) and if you can get a couple of fans pointed at the cats as well that will help.
Interestingly, having seen a few 'VMax' tunes from people who switched over to our stuff, one of the most concerning things was the fact that some of the protection mode maps had been edited to lean out the AFR. My guess is that the tuner was running the car on the dyno and seeing rich mixtures and editing the tables thinking they were the optimum fuel strategy, when in fact the car was just too hot and they were editing the safe mode tables.
We are well into the 100's of tunes for these and the V6 engines, multiple dyno sessions and I've yet to see a set of plugs go bad as a result. I would monitor your cat temps and allow more time between runs, before you go changing them.
There was a big fan on the front of the car..
  #62
Old 03-21-2017, 11:58 AM
JVIII's Avatar
Also, to the OP - see you joined recently. Welcome to the forum, it's a really good crew here, and your car looks fantastic. Congrats!
Thank you sir!
  #63
Old 03-21-2017, 12:09 PM
DJS's Avatar
DJS
DJS is online now
Received 2,074 Likes on 1,378 Posts
In the 'maintenance' section of your Owner's Handbook, you'll find a section on 'Breaking-In'. Some people follow it to the letter, some blow it off completely.
  #64
Old 03-21-2017, 12:13 PM
JVIII's Avatar
Hi Stuart,
What are your thoughts about the power dip at 5800-6100rpm? It dips then it climbs up quick.
Appreciate your response.
  #65
Old 03-21-2017, 12:45 PM
hoonery's Avatar
Even though I lease cars and hardly keep them long, I still follow it to the letter. What would I do without that extra 5 horsepower???
Besides, I'm doing someone else a big favor
Spark plugs going bad after 1700 miles sounds implausible to the point of unbelievable.
  #66
Old 03-21-2017, 01:57 PM
Unhingd's Avatar
Received 4,640 Likes on 3,362 Posts
Originally Posted by JVIII
Hi Stuart,
You didn't ask me, but on my V6S, the OEM power climbed to 6000 rpm, fell to 6500 and then headed north again to 6800. I believe all of our cars hit peak hp at around 6000 rpm until they are tuned.
JVIII (03-21-2017)
  #67
Old 03-21-2017, 02:20 PM
JVIII's Avatar
So I assume its normal?
  #68
Old 03-21-2017, 02:48 PM
Unhingd's Avatar
I believe so, but Stuart's team can speak with more authority.
  #69
Old 03-21-2017, 05:00 PM
sgvkirbster's Avatar
Default ETG (ecu tuning group)
Just curious guys.... Has anyone ever gotten a ecu tune from ETG (ecu tuning group)? The owner's name is Jags. I did a tune by him a few months ago (on my '14 BMW 650i Gran Coupe). Anyway, he tells me he can get my F-type R to 637 HP with tune and a pulley change. What do u guys think?
  #70
Old 03-21-2017, 06:26 PM
Stohlen's Avatar
No comment on pulling the front driveshaft? Did that happen?
  #71
Old 03-21-2017, 06:29 PM
JVIII's Avatar
Don't know what you mean by this..I have a similar rope that was on the rear of the car on the front when they were doing the dyno.
Lang Racing Development together with GSR did the Dyno..they do a lot of Exotic and High End Cars.
So they know their stuff.
  #72
Old 03-21-2017, 06:40 PM
Unhingd's Avatar
JVIII,
Was it an AWD dyno (rollers for front and rear wheels)?
  #73
Old 03-21-2017, 06:41 PM
With a tune and the crank pulley, yes that's a reasonable expectation. We expect to see similar numbers on ours. On an upper supercharger pulley probably slightly less than that.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
sgvkirbster (03-21-2017)
  #74
Old 03-21-2017, 06:43 PM
JVIII's Avatar
JVIII,
Was it an AWD dyno (roller front and rear)?
Yes sir, front and rear roller. The equipment that we used was Mustang Dynamometer.
  #75
Old 03-21-2017, 06:44 PM
JVIII's Avatar
Hi Stuart,
Probably you can chime in with my question
  #76
Old 03-21-2017, 07:22 PM
Hi Stuart,
Thanks Stuart!
  #77
Old 03-21-2017, 07:33 PM
Stohlen's Avatar
Okay, so they did not have to remove the front driveshaft from your vehicle to do the testing? Some dynos (including front and rear roller mustang dynos) do not have the front and rear rollers physically linked together, which would cause damage on the F-types AWD system. I saw your car on the hoist and thought they might be removing the driveshaft.
  #78
Old 03-21-2017, 09:14 PM
JVIII's Avatar
Correct..I don't see them removing it. Just the cover panel to tie the straps.
  #79
Old 03-30-2017, 02:16 AM
zmoothg's Avatar
So what happened here. Before and after graph?
  #80
Old 03-30-2017, 07:04 AM
JVIII's Avatar
We did a dyno again on Tuesday but the stock reading is still not good. I have a schedule with Jaguar Service to have it checked since the car feels like its misfiring at 5,600rpm.
Once this is resolved then we can move forward with the tune again.
