2018 seized engine?!?!
Old Jan 11, 2025 | 11:49 AM
2018manualftype's Avatar
Default 2018 seized engine?!?!
This is a post I was hoping I would never be the one to have to make. I took the car out a few weeks ago since the weather was nicer than it usually is and there wasn't any salt on the roads. Got about a mile from my house and the car felt wrong, like there was a hiccup. Said, alright I will turn around and take a different car, deal with this when its warmer. It got worse then suddenly the car just died. Couldn't re-start it. Had the car towed to a local mechanic. They are now telling me that they can't turn the crank no mater what. He thinks the engine is seized.
How screwed am I, is there anything else on this engine that could cause the crank to not turn? I am going to have to find a good local Jag guy and have it towed there (recommendations for north west NJ would be appreciated) and have them look at it, but I am kinda worried here, the engines for this car aren't cheap!
Thanks guys, wish me luck, I could use it!
Old Jan 11, 2025 | 11:57 AM
Adam Deermann's Avatar
How is the oil level?
Old Jan 11, 2025 | 11:58 AM
Dogbreath!'s Avatar
Hydro lock?
Old Jan 11, 2025 | 12:23 PM
Originally Posted by Dogbreath!
Hydro lock?
Dumb question, how would one know the difference? It was pretty cold out and had been very cold before hand
Old Jan 11, 2025 | 01:02 PM
SouthSider's Avatar
I doubt hydro-lock. Water would have come out of a spark plug hole when removed.
Again, was oil low or a milky brown color?
How many miles?
Old Jan 11, 2025 | 01:23 PM
lizzardo's Avatar
It could be something jammed up in the bell housing. When I looked at the failed Gen 1 clutch/flywheel parts after warranty replacement there were clearly loose parts. I didn't inspect very carefully but the dual-mass flywheel seems to have partially come apart.
Old Jan 11, 2025 | 01:25 PM
Turko's Avatar
Default Mr North Jersey .....
Sorry to read about your car trouble.
Im located in Morris County NJ.
I know of an excellent independent mechanic who specializes in service & repair to Range Rover vehicles and Jaguar cars.
The auto shop is in Essex County.
Where are you located?
Old Jan 11, 2025 | 01:54 PM
Dogbreath!'s Avatar
The OP had no mention of having the spark plugs pulled, but that would be a step towards figuring out what's going on. With the plugs out, if the engine cranks and water sprays out of the plug holes, that's your answer. Hydro locked engines are often, but not always, toast. Sometimes you can get lucky and simply crank the engine until the cylinders are empty then hope that it didn't do any damage to the crank, etc. Hydro lock could occur if you have an aftermarket intake that is mounted low enough that that driving through a puddle causes the engine to suck up water through the intake.
Another possibility is that the coolant froze and cracked the block and allowed coolant into the combustion chamber as the engine warmed. This could also cause hydro lock. I've had coolant freeze on a Tercel, but I caught it before any damage was done. I happened to notice that the temp gauge was not moving and I didn't have heat in the passenger compartment. Opening the radiator revealed slushy coolant. Disaster averted by letting the coolant thaw due to the engine heat, running the engine for a minute or two. Rinse and repeat until the coolant was thawed.
Could also be something like the timing chain broke. If it is an interference engine (dunno if it is) then a valve could be hitting a piston preventing the engine from moving. If it's not an interference engine then the repair is pretty straightforward.
At any rate, prepare yourself for a salty repair bill.
Old Jan 11, 2025 | 02:18 PM
Valerie Stabenow's Avatar
Default Many have reported success with these folks
Hope it turns out to be something inexpensive and easy. Here's a link to a rebuilder:
https://tapajaguarlandroverengines.com/
Old Jan 11, 2025 | 03:00 PM
Supersprint Sport Exhausts's Avatar
Default California shop would be long distance transport
It's best to find a local shop.
The OP is in NJ.
Old Jan 11, 2025 | 03:08 PM
lizzardo's Avatar
I'm serious about checking that something hasn't jammed the flywheel in the bell housing before tearing into the engine. I'm not sure what generation clutch and flywheel you've got but failure rate on Gen1 is alarmingly high. I was going to say "near 100%" but I don't know the actual numbers. It just seems that way.
Old Jan 11, 2025 | 04:05 PM
Low oil, can lead to oil starvation to the bearings, witch can cause a lock up.
This is what I found in my engine, could hardly be turned. Mine is very rebuildable. A hint was metal parts in the oil filter.
A former rod bearing
Journal seems good
Journal seems good
Old Jan 11, 2025 | 04:15 PM
I'm near Lake Hopatcong at the border between Morris/Sussex
Old Jan 11, 2025 | 04:17 PM
You know, now that I think of it I did half wonder if something was up with the clutch right before it happened.
Old Jan 11, 2025 | 04:33 PM
Quan Jordan's Avatar
Bro I hope everything turns out ok. Same thing happened to me, but the infamous "Y" Pipe failed on me after a quick race that I won. Sat there and talked with the other driver with both our cars running for a few minutes, drove off and lost power about a mile down the road. No warning lights, noises, smell...nothing. Just died all of the sudden. I bought a used motor off ebay from a reputable dealer for 6,500 with 37,000 mi. on it(mine had 77,000 on it) and now a few thousand miles later I'm still enjoying my baby.
Old Jan 11, 2025 | 04:58 PM
How bad was the install? I am seeing $5kish
Old Jan 11, 2025 | 05:16 PM
Yep I got a deal for $3,000 though because I know the guy so well, been doing business with him for almost twenty years.
Old Jan 11, 2025 | 07:50 PM
Turko's Avatar
Default 2018manual, here's the service repair shop info
C & G IMPORTED CAR REPAIRS
780 Bloomfield Avenue, Verona New Jersey
973-239-9726
The shop is constantly purchasing auto parts from Paul Miller Jaguar, Parsippany New Jersey. They specialize in Range Rover and Jaguar vehicles.
Keep us updated.
Old Jan 12, 2025 | 09:15 AM
Carbuff2's Avatar
Me too. In fact, I bet we are both in Roxbury Twp.
Another shop that is well-liked is Marotta Motors in Hawthorne NJ. Mario is a JLR Specialist.
Old Jan 12, 2025 | 09:24 AM
Robert R Gilbert's Avatar
Joe Augustine at 12VoltDoctor in Staten Island does engine replacements. I hope it does not come to that.
