3rd brake light above rear window
Old Nov 1, 2019 | 05:25 PM
powerhouse's Avatar
Default 3rd brake light above rear window
Anyone with Topix can show me how to get into the rear of the 3rd brake light
Old Nov 1, 2019 | 05:47 PM
OzXFR's Avatar
From the Workshop Manual:
Old Nov 1, 2019 | 09:17 PM
lizzardo's Avatar
That procedure is for R&R (Remove and Replace) but doesn't answer the question of how to get into it. I think the answer to that is that it's not designed to be serviced other than as a complete unit. Mine had condensation inside and no attempt was made to service the unit itself. It was replaced.
Old Nov 1, 2019 | 09:46 PM
OzXFR's Avatar
Agreed.
It uses LEDs and all other Jag rear light LEDs I've ever read about are not serviceable, it's a complete new unit or nuffin.
On the F-Type even the overhead console lights are LEDs and even after I removed the console itself from the roof I couldn't see any way to open it up (short of a plasma torch!) to service or replace the LEDs.
Old Nov 2, 2019 | 08:01 AM
Unhingd's Avatar
Thanks for the info. I've got the full shop manual, but wasn't looking forward to hunting through the 30,000+ pages to find it. I have a flashing module that I will install behind the light that will flash it 5 times before going full red when braking.
Old Nov 2, 2019 | 03:03 PM
powerhouse's Avatar
For me I want to tap into the power for the 3rd brake light, tried to get in through the rear boot to the back of the rear light, to much trouble, pulled out a bit of the trunk liner then foam round the light and as for trying to see anything, ah I gave up, wonder which wire contains the power
BonesXJR
May 21, 2021 03:19 PM
larney
Nov 18, 2019 06:11 PM
Ipc838
Apr 27, 2017 10:30 AM
jsimmons
US Western
Mar 1, 2016 12:21 AM
inertian
Mar 18, 2014 09:09 AM
