719 horsepower F Type R
Old Nov 18, 2023 | 07:47 AM
Turko's Avatar
Default 719 horsepower F Type R
Hi guys,
Does anyone know anything about this company? The guy is stating the car has 719 horsepower, with all of the added modification parts. Interesting video.
Your thoughts please.
Old Nov 18, 2023 | 03:33 PM
Gasman2's Avatar
As I understand it
twin pulley
Air filters
Sportscats
Larger intercooler
Live mapped on rolling road
Old Nov 18, 2023 | 03:42 PM
Gasman2's Avatar
I have also heard Lister have entered the tuning market with their own upper pulley design and ECU tune and retaining the 666bhp and 880nm of torque that the lister 666 achieved without having to change the crank pulley
not sure how this is achieved but I can only assume the bleed of point has been raised to achieve the same power as a twin pulley set up
Old Nov 19, 2023 | 03:06 AM
scm's Avatar
scm
What transmission are they using to cope with that torque?
Old Nov 19, 2023 | 03:23 AM
Gasman2's Avatar
Standard 8 speed
that figure is comparable with all the other tuners it's not leaps and bounds ahead
Old Nov 19, 2023 | 03:02 PM
scm's Avatar
scm
Standard 8 speed
880Nm of torque, through a box rated at 700?
Old Nov 19, 2023 | 03:10 PM
Gasman2's Avatar
Unless I am mistaken most of the tuned f types are running that
Old Nov 22, 2023 | 07:18 PM
Stuart@VelocityAP's Avatar
They are not doing this without the crank pulley, it's both. If you could get this much power with just an upper pulley, we would have done it a long time ago. The bypass valve is basically closed on all tunes once you've passed a certain RPM & load point.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Nov 22, 2023 | 07:20 PM
The HP70 is very robust, we've got literally thousands of customers running well over 600ft/lbs, no problems. If you look at some of the other applications, BMW, Dodge etc. there's tons of people running them well over their rated capacity.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Nov 22, 2023 | 07:21 PM
Originally Posted by Turko
Hi guys,
https://youtu.be/3qrtUGvCYes?si=FDtHX6J_Yk6sgakh
I'm not going to comment at this point. But we'll be releasing some interesting information fairly soon.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Nov 23, 2023 | 03:13 AM
Andi Jaguar G's Avatar
for me, the only interested Component is this solution in my view! What do you think?
Thank you for all answers...
JAGUAR SUPERCHARGER CHARGE AIR COOLER
https://www.wraptorcustoms.com/product/jaguar-supercharger-charge-air-cooler-wraptor-performance-cooler-type-1
Old Nov 23, 2023 | 04:07 AM
Gasman2's Avatar
Yes I have one of these fitted
it won't add power but it will help keep the charge temps down
Old Nov 23, 2023 | 07:46 AM
I understand, thank you for your feedback. If it doesn't deliver more power, you could then say that it maintains performance better at higher outside temperatures! So in the end it delivers more performance, but not more than in cool temperatures! Could you say it like that?
Old Nov 23, 2023 | 07:54 AM
Gasman2's Avatar
Yes it helps maintain lower intake temps due higher volume of water
Old Nov 23, 2023 | 09:33 AM
inmanlanier's Avatar
By definition 'keeping the charge temps down' adds more power. Temperature directly correlates to density. Higher density of air means more O2 per mole of air moved through. More 02, more HP.
Old Nov 24, 2023 | 11:04 AM
clubairth1's Avatar
Community Influencer
Just a note on that IC?
I installed on my XJR and have zero complaints! Here is my install thread.
XJR IC Upgrade
BUT do get it from the people that make it?
It's cheaper that way and I over paid by about $500 before I got it and saw the sticker on it that said Paramount!
What's nice is this continues to drop in price since I got mine. Also the same IC is used across the Jaguar product line so it fit's most Jaguars.
As the ad shows is was 1000 GBP and now has been reduce to 699 GBP. About 80 GBP cheaper.
Upgraded IC
Old Nov 24, 2023 | 11:17 AM
Gasman2's Avatar
The intercooler from wraptor is bigger than paramount/viezu and as far as I know the thickest intercooler presently available
Old Nov 24, 2023 | 11:58 AM
Dale Melton's Avatar
Might this be the TVS2300 supercharger upgrade Stuart?
Old Nov 24, 2023 | 12:10 PM
XJR IC Upgrade
Upgraded IC
https://www.allisport.com/
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Nov 24, 2023 | 02:56 PM
Gasman2's Avatar
the wraptor chargecooler is way bigger than the paramount one and far better value
