Adding an extra heat exchanger
Old Aug 7, 2019 | 05:39 PM
Terrance39's Avatar
Default Adding an extra heat exchanger
Being that I live in Texas and this heat is crazy. I decided to add a extra heat exchanger to my car. My mods are dual pulley, intake, methanol, tune, and 300 cell cats. Heat is the enemy. I had a stock heat exchanger from a Audi s4 and the size was perfect. I did a little trimming, made some brackets and it mounted up great. I used clear coolant hose here to make sure everything was flowing great etc. The end results were that I increased my coolant capacity by 2 quarts and the car is way more consistent. Coolant temps have also been amazing too.
Old Aug 8, 2019 | 03:31 AM
peppersam740's Avatar
Love your air intakes
Old Aug 8, 2019 | 09:25 AM
Terrance39's Avatar
thanks, the whole system is custom made.
Old Aug 9, 2019 | 12:14 PM
XJ8JR's Avatar
How did you route the hoses?
Old Aug 9, 2019 | 12:44 PM
Terrance39's Avatar
Ran it out the pump into the exchanger, then back into the hose that originally came out the pump.
Old Aug 9, 2019 | 01:49 PM
XJ8JR's Avatar
Just when I think I'm all done with mods...sigh
Thanks for the info!
Old Aug 9, 2019 | 03:54 PM
XJ8JR's Avatar
Dumb question...which is the outlet on the pump?
Old Aug 9, 2019 | 04:03 PM
Terrance39's Avatar
Old Aug 9, 2019 | 04:04 PM
XJ8JR's Avatar
Thank you, sir!
Old Aug 16, 2019 | 06:48 PM
XJ8JR's Avatar
I'm not sure if the FType has headlight washers but the XJ does and I'm wondering if it might be beneficial to use the existing plumbing to rig up an heat exchanger mister...
Old Aug 16, 2019 | 06:51 PM
Terrance39's Avatar
Yes it does have headlight washers. That would be really simple to actually rig up lol. But with the extra heat exchanger and meth. Heat is not an issue for me at all lol.
Old Mar 15, 2022 | 08:10 PM
Terrance39's Avatar
I went with a much better heat exchanger on my SVR. I also upgraded the pump. Much better results.
Old Mar 16, 2022 | 06:29 AM
skizot's Avatar
@Terrance39 is so modest. His new setup is sick. He has been nice enough to share some of the details he's worked on for this upgrade. If not mistaken, I think it adds almost an extra gallon of coolant and with the CWA100 pump, recovery times are significantly quicker. Great job!!!
Old Mar 16, 2022 | 02:34 PM
XJ8JR's Avatar
Is there any concern that the new heat exchanger is blocking air flow from the lower grille to the main engine radiator?
Old Mar 16, 2022 | 02:36 PM
Terrance39's Avatar
No, not at all. You still have the upper opening. Plus i have seen zero evidence that would support that. I've been running this for a long time now.
Old Oct 24, 2022 | 03:16 PM
Reaxions's Avatar
What exchanger did you end up with?
Old Oct 25, 2022 | 05:35 PM
Doc Oc's Avatar
I just finished this same project last weekend. Went with this exchanger:
Amazon Amazon
Went with this one because it fits in the opening perfectly and both ports are on the same (pump) side. Also replaced the oe pump with a pierburg cwa150 and ran the new HX right in front of the oe one, plumbing it between the pump and awic's. Also disconnected the SC cooling system from the engine cooling system via adding a reservoir to the top hose on the oe SC HX and capping off the engine coolant side port that joined them. So far so good. Here's a couple very poor pics:
Old Oct 26, 2022 | 05:29 AM
Guardian's Avatar
Very interesting topic.
Wonder how is reliability of such Aliexpress HX.
Also do you have some more photos of system routing?
Old Oct 26, 2022 | 08:36 AM
Doc Oc's Avatar
If you look at this diagram VAP kindly provided, it may help. I put the new HX inline on hose 8. Ran a short hose from pump out to new HX in, then attached the oe end of #8 to the outlet of new HX. This is why it's important to get a HX with both outlets on the same side or you'll be rerouting like crazy. #7 gets capped off on the engine side and a reservoir attached to it on the sc side. Hoses 5 and 9 stay where they are.. Minimal excess plumbing with this routing. This will also work fine without messing with #7 and leaving the two systems joined.
If you look at my pics above I had a decent size length of hose going from pump out to the new HX in. I started to worry it might kink when it got hot so I added a 90 deg elbow and got rid of about 6" of that hose. Much cleaner and won't kink. No pics though.
Old Oct 26, 2022 | 11:00 AM
Gearhead01's Avatar
This is great information. Can you provide any details on the reservoir you added? Also, any additional photos of the installation would be very helpful.
