Amp bracket rattle
Old May 25, 2017 | 11:03 AM
f_in_seattle's Avatar
Default Amp bracket rattle
Hi guys,
does anyone know how to get to the amp (amplifier) brackets in the rear? I had a rattle coming in from the back and I've been to the dealer twice due to a rattle coming from the rear and each time they've tightened the bracket which solves the rattle for a few days till it comes back again.
My issue is further complicated by laser jammers which I've had installed and are probably somehow housed there since the dealer said there is aftermarket equipment causing the bracket to come loose.
I don't want to keep going back to him and was wondering if there is a schema or easy way to get to it myself so that I can look at whats going on and maybe even keep tightening it myself each time it becomes loose rather than having to schedule an appointment with the dealer.
Thanks in advance!
Old May 27, 2017 | 05:21 AM
jaguny's Avatar
Once you find it, can't you use a locking washer or locktite to keep it from coming loose?
