anyway to disable to lock horn?
Old Mar 24, 2017 | 06:53 AM
  #41
Dogbreath!'s Avatar
Originally Posted by Unhingd
The service people at my dealership are unaware of the issue, but the Meridian service bulletin specifically instructs the technician to disconnect the battery and hook up an external power supply while the flash is taking place, so the Meridian upgrade should not trigger the problem.
Interesting. Why wouldn't the instruction just say to hook up the power supply while the battery is still connected? Maybe they know about the issue but don't have a fix?
Old Mar 24, 2017 | 07:08 AM
  #42
Unhingd's Avatar
That's what I am suspecting.
Old Aug 22, 2017 | 03:23 PM
  #43
15FTypeR's Avatar
I'm going to replace the "honda meep" sound with a more appropriate arming "beep" (perhaps similar to toyota).
Anyone found a device that makes the correct sound? I know how/where to hook it up, just need to source a 12v beeper.
I know you can turn off the honda meep, but if a friend pushes the door handle while i am inside the car, it still "meeps" which as noted is a really terrible sound.
Old Aug 22, 2017 | 04:09 PM
  #44
ek993's Avatar
I tried to disable the beep by unchecking the "audible lock warning".... didn't work, it still beeps....
Old Aug 22, 2017 | 04:23 PM
  #45
zmoothg's Avatar
I did, but you need to know how to read wiring diagram to find the correct wires to hook it up right. I have not investigated how to prevent the horn from going off when someone pushed the door handle. I will look at the electrical wiring diagram to see if the unlock/lock module connects directly to the horn output, if it connects through the CANBUS there is not much one can do without hacking into the software.
Edit: It looks like it might be possible to disable the horn at the BCM (Body Control Module). It appears the steering wheel horn trigger is on a different relay than the horn from the central locking system, which indicates you can disable the the central locking from setting off the horn, but the downside and a reason not to do that is that this also means you are essentially disabling the audible theft alarm as well. Reprogramming the BCM is the only way to do this perfectly.
Old Aug 23, 2017 | 12:44 AM
  #46
15FTypeR's Avatar
I already have all the technical details worked out so I'll have a solution for this evil horn as soon as the new beeper arrives which should be in about a week.
I'll post detailed instructions here once I install mine. Looks like it will be pretty straight forward and inexpensive.
Old Oct 30, 2024 | 06:14 AM
  #47
Nettayjae's Avatar
Lol. Right me too! It’s so annoying and such a childish sound🤣🤣🤣
Old Oct 30, 2024 | 07:14 AM
  #48
scm's Avatar
scm
Well, we've waited patiently 7 years for those detailed instructions ....
Old Nov 1, 2024 | 06:28 AM
  #49
Jag Bass's Avatar
Just unplug it, its not the same a the vehicle horn, at least in the 20R. I actually unplugged mine and plugged in a 12v piezo beeper so now all I get is very subdued chirp chirp.
