A brief but concerning squeak
Old Dec 12, 2019 | 12:22 PM
RacerX's Avatar
Banned
Default A brief but concerning squeak
I am at 38,000 miles. Has anyone else had a brief chirp-like squeak when accelerating a little harder than mild up-shifting between lower gears?
It's is easy to hear with the top down, but not that loud with the top up. It lasts for a fraction of a second, exactly at gear change. It sounds like its coming from the rear underside or possibly from the middle underside of the car, but its hard to pin down from the cabin. It can be recreated when accelerating a little harder than comfortable and up-shifting, but I think I heard it once when twisting the suspension over a rut with no gear shift.
Things I've tried
  • Added dreaded belt dressing to the serpentine belt just to see if the sound changed - nope
  • Lubricated the rear suspension - no change
  • Re-torqued the wheel lugs and spacers too 100 ft-lbs, usually I tighten to 92 ft-lbs - no change
Remaining suspects
  • Could still be serpentine belt jolt, but I think the sound is more central to the car
  • eDiff or fluid - no leaks, looks brand new from the outside, no other issues
  • Drive shaft?
  • ZF8?
  • Brake pads - which do squeal intermittently
  • Suspension bushings - all look fine
I still have CPO left for 10 months, but it only covers drive-train and electrical failures AFAIK so this might not be covered or entertained. I have a little time to see if it goes away or gets worse. I was hoping someone might know of a similar issue/solution? Any thoughts or recommendations?
Old Dec 12, 2019 | 02:25 PM
glenn b's Avatar
I had this on my previous XF. It was the gearbox. It went away after i had the fluid changed. The box in that car was the 6 speed version of the zf 8 speed we have in the F Type.
Old Dec 12, 2019 | 02:42 PM
scm's Avatar
scm
I think the "chirp" was a known issue some years back with ZF auto boxes. Seemed to be cured, or at least mitigated, with a fluid change. I'm surprised if you need a fluid change at 36k (I think ZF say 60k), but I don't know how or where you drive.
Old Dec 13, 2019 | 12:04 AM
RacerX's Avatar
Banned
Thanks all, I ordered ZF's HP70 fluid change kit including the pan, filter, and magnets for under a little under $300. Looks like ZF's change interval is 50K miles or 8 years under normal driving, so its not far from due.
DJS's Avatar
DJS
Your description also sounds like a squeaky exhaust valve, though mine make more of a squeaky grindy noise.
Old Dec 13, 2019 | 12:07 AM
RacerX's Avatar
Banned
But Fuse 43 is in my glove box.
Old Dec 13, 2019 | 06:51 AM
Carbuff2's Avatar
@RacerX PM sent
Old Dec 13, 2019 | 06:24 PM
Luc Lapierre's Avatar
Ah yes.
I get this from time to time on hard acceleration around 6,000 rpm in low gears (1-3). Not sure if it's related, but it only seems to happen when it's a bit colder out. Sounds like a bit of belt squeal.
It's on my "please investigate" list for the next big dealer visit.
Old Dec 20, 2019 | 03:32 PM
RacerX's Avatar
Banned
I drained my ZF8, refilled, ran the car a bit to mix the fluid in the torque converter​​​, drained again, changed the pan which included a new filter and magnetics, and refilled IAW the two step up to temp method as prescribed. All is good now, no squeak.
​​​​​​I decided to go with Amsoil's Signature Series ZF8HP700 fluid, since the OEM fluid didn't even last 40K miles. Hopefully it performs better. The shifts feel a little better already, but a little time will tell.
https://www.amsoil.com/lookup/auto-a...l-l/us-volume/
CThomas
Nov 30, 2017 09:12 AM
PILLZ
Nov 5, 2014 08:18 AM
Marco
Feb 10, 2012 05:05 AM
MTW
17
Nov 3, 2011 10:16 AM
Leedsman
General Tech Help
Oct 28, 2010 03:11 PM
