change brake pads
Old Sep 25, 2018 | 09:10 AM
DJS's Avatar
DJS
Originally Posted by bjg625
On '14 you had to buy performance package to get the bigger brakes on V6S, after that I don't know. V8 came standard.
V6S came with 'high performance' brakes (black calipers standard, red optional), which are bigger than 'performance' brakes on the base. Optional larger brakes were 'super performance.'
https://www.dropbox.com/s/x0x62a2t0z...rakes.pdf?dl=0
Old Sep 25, 2018 | 11:12 AM
indietor's Avatar
ok i have the standard so why they are red ? it was an option ?
Old Sep 25, 2018 | 02:22 PM
Unhingd's Avatar
yes. Do you have 18” wheels?
Old Sep 25, 2018 | 06:29 PM
OzXFR's Avatar
He has 19" wheels, see the pic in post #4.
Old Sep 26, 2018 | 02:47 AM
indietor's Avatar
19'' and 20''
Old Sep 26, 2018 | 05:49 AM
Kirk Morey's Avatar
My indicator light hasn't come on yet, but my pads have been flagged at my service last week for replacement. My dilemma is, I would like to change them out for the low dust ones like the EBC 'Red Stuff' ceramic ones..
Ordinarily, you would think that wouldn't be a problem but I live in Dubai, and trying to get anybody to commit here without me giving them double super secret conformation that they are indeed the "EXACT' right thing before they will let me order them (in case they have to be returned), and therein lies my problem.
I have a lovely little base, 2014 3.0 in Iridium Silver, 19" "propeller" wheels, nothing super special about it (apart from the fact that is is already special as it is) and I would if possible like a bit of help in making sure that I order the right pads for my car.
I will be ordering them from the UK or the States, but my car is a GCC (UAE) spec car, I take it (hope) there is not a huge amount of differences??
Old Sep 26, 2018 | 05:56 AM
OzXFR's Avatar
See this page: https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=EBC+redst uff+Jaguar+F-Type+base&_sacat=6000
You want the first two listings, DP32191C for the front and DP32190C for the rear.
That is assuming you have the standard F-Type Base brakes, 355 mm front and 326 mm rear, check the OP's pics to see if yours look the same.
You really only need to check the fronts, if they are the 355 mm then the rears *must* be the 326 mm, as no F-Type ever left the factory with 355 mm fronts and 376 mm rears.
Old Sep 26, 2018 | 06:02 AM
  #28
Kirk Morey's Avatar
Originally Posted by OzXFR
See this page: https://www.ebay.com/sch/i.html?_fro...se&_sacat=6000
Many thanks, but I neglected one bit of information, mine is a convertible, no difference I take it?
Old Sep 26, 2018 | 06:08 AM
OzXFR's Avatar
Makes no difference at all.
Edit - the eBay Motors link I posted has gone haywire, so instead you should bring up eBay Motors and simple search under DP32191C and DP32190C.
Old Sep 26, 2018 | 09:27 AM
  #30
indietor's Avatar
i leave the car at jaguar dealer
they said probably 1000 eu will be the cost ? i was thinking less
brake pads front and rear
Old Sep 26, 2018 | 10:13 AM
  #31
Unhingd's Avatar
it should be a lot less.
Old Sep 26, 2018 | 11:56 AM
  #32
F-Envy's Avatar
Kirk,
I just finished installing the EBC Red stuff pads on my 2019 with the super performance brakes, 380mm front, 376mm rears. Front pads were DP32191C, rears DP32192C. For the standard brakes I think you need: fronts DP32189C and rears DP32190C.
Old Sep 26, 2018 | 12:43 PM
  #33
eeeeek's Avatar
Yer on!
I would bet real money it is the rear pads as in my experience and research the Jag rears wear twice as fast as the fronts.
Except that I note in one of the OPs pics the outer "face" of the rear brake pad looks almost new it is so clean, so maybe the rear pads were renewed not long ago?
Seriously? I haven't heard of a car where the fronts wear at a lower rate than the rears. I remember always changing the fronts much more frequently, which makes sense as the majority of braking is accomplished by te front brakes...
Old Sep 26, 2018 | 03:10 PM
  #34
Unhingd's Avatar
The front pads are much larger and have much more material to give. Also, in the olden days before ABS, the braking power was proportioned mostly towards the front, causing the front pads to wear out more quickly. With ABS, the braking force of the rear brake pads is more fully utilized causing them to wear out more quickly than in the past. The rear pads on my mini do indeed wear out more quickly than the front. Also, when I replaced the pads during the Wortec installation, the rear pads did indeed look like they had more wear, but I don’t know what the new pad depth was, so I can’t confirm.
Old Sep 26, 2018 | 04:00 PM
  #35
eeeeek's Avatar
Well shoot. I hate it when I have to change my view on core truths...
Old Sep 26, 2018 | 06:17 PM
  #36
OzXFR's Avatar
All Jags since around 2008 have had "anti-dive" built into the braking system.
Under medium and above brake pedal pressure this applies the rear brakes fractionally earlier and a bit harder than the front brakes.
Also I find that the handbrake/parking brake/emergency brake release sometimes causes the rear pads to "groan" a little, whether I manually release or allow the car to auto release.
These two things plus the stock soft rotors and pads cause the rear brakes on Jags (both pads and rotors) to wear fairly quickly and in most cases quicker than the front brakes.
Old Sep 26, 2018 | 07:04 PM
  #37
OzXFR's Avatar
Originally Posted by F-Envy
Kirk,
Yep, seems you are correct, DP321189C = front 355 mm and DP32190C = rear 326 mm (both Redstuff).
Old Sep 26, 2018 | 07:09 PM
  #38
OzXFR's Avatar
That is a complete rip-off!
Assuming you can't or don't want to DIY, is there somewhere else you could take the car to get the brake pads replaced?
A reputable brake/suspension shop?
Also, if you get it done at the dealership they will probably insist on supplying and fitting OEM brake pads and refuse to fit EBC Redstuff pads.
As you know the OEM pads are incredibly dusty but by all reports the EBC Redstuff pads are very low dust so you really should go with them if you can.
Old Sep 27, 2018 | 06:38 AM
  #39
Paul_59's Avatar
Banned
Agree with the rip off comment.
I will sometimes source parts myself and ask a dealer to fit them, occasionally there is reluctance on part of dealer to do so. I adopt this approach for one or two reasons, one I want a specific manufacturer part. The other reason is whilst I accept dealers wish to make a profit on the labour charge and the parts supplied and I am fine with this, what I won't accept is being charged more for parts than I can purchase the same item for without the benefit of trade discount or multiple item discounts.
When I have asked dealers to fit parts I have supplied their initial reluctance has vanished when I explain the option is to make money on the labour charge only or don't get my business as I will go elsewhere
Old Sep 27, 2018 | 11:20 AM
  #40
indietor's Avatar
finally the bill is 936 eu
pads front
sensor new
pads rear
sensor new
that's it
