Coat hook removal
Old Mar 3, 2021 | 04:49 PM
crashxx's Avatar
Default Coat hook removal
Is it possible to remove the coat hooks behind the seats to gain a little more reclining room?
Old Mar 3, 2021 | 06:11 PM
OzXFR's Avatar
I would say it is possible.
I just had a look at the one behind my passenger seat (LHS on my car) and it is loose and wobbly, no idea why.
Loose enough so I can see/tell it is bolted or screwed onto the plastic panel from behind, probably two screws or bolts, and odds on you can remove those screws or bolts once you have pulled that panel off.
Edit - forgot to add, the seat back has an inbuilt hollow/indentation which fits over the coat hook such that when the seat is fully back/reclined the coat hook doesn't touch the seat at all, so removing the hooks is not going to help.
At least that is the case with the "performance" seats on my car, dunno about the "sports" seats but I would bet they are the same.
Old Mar 3, 2021 | 08:04 PM
crashxx's Avatar
Interesting, the window sticker that came with my car says performance seats, but no indention in the back. It looks like if I could remove it I could gain a little recline.
Old Mar 3, 2021 | 08:14 PM
OzXFR's Avatar
I just twigged that you have a 19R.
I'm fairly sure the 19 got redesigned / slimmer seats and if so that might explain why you have no indent in the back.
godfrey
General Tech Help
Sep 16, 2020 06:56 PM
mcypert
Jun 1, 2020 07:22 PM
Shadow993
Dec 21, 2016 08:09 AM
anthawk
Jun 12, 2016 12:20 PM
wjhughes420384
Jan 27, 2008 12:02 PM
