code p0430
Old Jun 8, 2024 | 12:53 PM
santacruz11's Avatar
Default code p0430
could code just be oxygen sensors ?? or does it mean my cats are both bad and how do i ell ?? thanks in advance car runs great does like feel like the cats are blocked
Old Jun 29, 2024 | 02:38 PM
clubairth1's Avatar
Community Influencer
P0430 bad drivers side cat.
P0420 bad passenger side cat.
You can try some cleaners to see if it helps??
If you think it's an O2 sensor just swap it side to side and see if the code changes to P0420. If so change the O2 sensors (Both of them). These will be the post cat O2 sensors.
Old Jun 29, 2024 | 04:38 PM
lizzardo's Avatar
The P0430 code doesn't mean the cat is necessarily bad. It indicates "catalyst inefficiency" and that is based on comparing the readings of the sensors fore and aft of the converter. If it sees that there isn't enough difference between the two it throws that code, but I would look to the sensors first as they are a known issue.
EDIT: Since the warranty for the sensors has been extended, I'd recommend having the dealer diagnose it. If it's the sensor(s) it should be fixed at no charge.
Lorenzo Bell
Jul 29, 2016 09:57 AM
