Confusion on SVR Lower Deflector
Old Jul 29, 2021 | 09:34 PM
rcgrabbag's Avatar
Default Confusion on SVR Lower Deflector
Hi everyone, first time poster and I'm hoping someone can help me solve a bit of a mystery with front bumper parts. I have a 2018 F-Type SVR and I scuffed up some of the plastic pieces on the bottom and looking to replace. The mystery item is a plastic piece UNDER these two deflectors that stretches from one side of the car to the other.
I don't see this part listed. I see two items they are calling Side Spoilers (L&R, T2R11276, T2R11277), but this thing I'm seeing on my car is one piece.
Attached is a pic that hopefully illustrate what I'm seeing. Here is the link to the bumper breakdown with part numbers: https://parts.harperjaguar.com/v-201...mponents-front
Any idea what this part is? Any help would be much appreciated!!!
Mystery part stretching from the passenger side deflector across the center deflector to the driver side deflector
Old Jul 29, 2021 | 09:42 PM
OzXFR's Avatar
I don't have an SVR but I am fairly sure you are talking about the "under cover", part # T2R20597 and # 13 in the graphic.
I have removed this piece a few times on my 2014 S coupe and it's a PITA coz it uses around 3,457 bolts and screws, and I think it's the same part across the F-Type range from year to year and model to model.
Old Jul 29, 2021 | 09:43 PM
rcgrabbag's Avatar
A bit of clarification. This mystery piece is under both side deflectors and center deflector. It's one piece stretching from one side of the car to the other. One of the side deflectors shown in this pic below:
Side deflector
Old Jul 29, 2021 | 10:05 PM
OzXFR's Avatar
Side deflector
Doesn't change what I think, I still reckon it is part # T2R20597. Those side deflectors bolt on top of (under) it.
Check to see if the part you are after extends back under the car by about 50 cm and if it does then it is T2R20597.
Old Jul 30, 2021 | 01:43 AM
Borbor's Avatar
With such a big front splitter on your SVR I wouldn’t even both replacing it as you can not even see it. It is a sacrificial part anyways and will only last until you next spoondrain or driveway mishap. Cheap to replace if you still want too though
Old Jul 31, 2021 | 05:50 PM
rcgrabbag's Avatar
Thank you for the responses. Pretty shocking how much the carbon fiber lower deflector is! $4,000 USD!
Guardian
Sep 20, 2025 02:27 AM
jagrodrigues
Mar 22, 2021 06:15 PM
Meister_Kajo
Jan 15, 2020 08:15 AM
John-Handy
May 24, 2018 12:17 PM
StealthPilot
Feb 14, 2016 08:20 PM
