Creaks during torsion flex / ramps
Old Jun 17, 2025 | 03:52 AM
J444G's Avatar
Default Creaks during torsion flex / ramps
My F-type creaks quite a lot when going on ramps (like 1 front wheel on a ramp in a underground garage for example). No car I have ever had done that to this extent, and I am sure F-type has the best torsional rigidity of them all...
It is not even a 1 isolated nose, it goes from dashboard, rear, sounds like the whole car is flexing.
Is this normal?
Old Jun 17, 2025 | 08:44 AM
Carbuff2's Avatar
Many posts here, about loose tubular strut braces in the engine bay. That is the best place to start.
If the issue persists, I would check the security of the under-body braces too. On our 'vert, they are in front (undertray), middle (over the exhaust) and in the rear (around the rear subframe).
And before you ask, approaching driveway/parking lot 'aprons' at a 45 degree angle is always advised, since that prolongs the life of the front lip.
Old Jun 17, 2025 | 11:38 AM
J444G's Avatar
Thanks, I did a quick strut brace check, tightened 6 bolts to 55 NM per manual. They moved a little, so fingers crossed. I did not tightened the part that goes in front of the windshield, since it is under a rubber and I have no idea how to get into it. Is there anything else to tighten under the rubber or not?
eeeeek
Dec 2, 2025 04:13 PM
crashxx
Apr 15, 2022 12:39 PM
Unhingd
Mar 7, 2015 04:09 AM
schraderade
Jun 20, 2014 10:18 PM
Scott Bourne
Photography
Aug 3, 2013 08:10 AM
