Custom spacers 10mm
Old Apr 26, 2015 | 04:59 PM
StealthPilot's Avatar
Default Custom spacers 10mm
I understand some guys here have ordered custom 15mm spacers however there were a couple of issues with that:
1) 15mm maybe too aggressive
2) Those particular spacers required the wheel bearing to be sanded down which to me is a completely unacceptable modification.
Anyone have any ideas of somewhere we can buy custom spacers which are 10-12 mm and don't require modifying the wheel bearings?
Old Apr 26, 2015 | 08:13 PM
Mahjik's Avatar
Lenny will make any size you request:
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
However, IIRC, it wasn't the bearing but the wheel studs which required shaving. This means if you go less than 15mm, then you will need to shave more of the studs (or replace the studs with longer ones and just have the spacers only be spacers).
Mac Allan
Jul 20, 2020 05:46 PM
waynepaulj
Oct 2, 2015 04:05 PM
Johncy2000
Oct 2, 2015 01:05 AM
XJ8JR
Sep 29, 2015 06:59 PM
