Door handles pop back out?
Old Apr 10, 2017 | 12:28 PM
drmerc's Avatar
Default Door handles pop back out?
This may be a stupid question but I just recently acquired a used 2017 F-type base and I'm still learning!
I'm trying to do the single lock mentioned in the manual but when I push the handles in they just pop back out.
Any ideas why or what I'm doing wrong?
When I use the key fob to lock it they do go in.
Old Apr 10, 2017 | 12:29 PM
Nati's Avatar
do you have your spare key in the car?
Old Apr 10, 2017 | 12:30 PM
drmerc's Avatar
It was a repo and I was told there was only one key because of that.
I'll search the car to see if there is a second hidden somewhere!
Old Apr 10, 2017 | 01:07 PM
ioneabee's Avatar
it will only work if you have the keyless entry system
Old Apr 10, 2017 | 01:24 PM
Nati's Avatar
to be clear if there is a key in the car and you try to lock the car by pushing the handle, the horn will beep twice and the car will immediately unlock again.
Old Apr 10, 2017 | 01:25 PM
Nati's Avatar
a quick test would be to take your known key and move it away from the vehicle, then hop in and try to start the car.
Old Apr 10, 2017 | 01:40 PM
drmerc's Avatar
It doesn't beep twice.
I push on the handle and it retracts completely then immediately pops back out without any beeping.
Old Apr 10, 2017 | 02:16 PM
Mueller's Avatar
Hmm. Either your horn isn't working (to beep twice to tell you there is a key being detected in the car) or something isn't right with your locking mechanism. You are still under warranty, why not take it to the dealer? Why you are driving (above 5mph) do the handles retract? Try and reach out of your windows to feel if they have retracted. If not, i'd wager that something is preventing them from closing and the system is sensing it.
Old Apr 10, 2017 | 02:19 PM
ioneabee's Avatar
may I once again refer you to my post above - if you don't have the keyless entry system - it will do exactly this ............ as mine does, because I don't have the keyless entry system
Old Apr 10, 2017 | 03:11 PM
Mueller's Avatar
Well I'll be damned. I just went to configure a based coupe, and you are correct. I did not know this car could be purchased without keyless entry. Do you have to insert a key to start the car?
Old Apr 10, 2017 | 03:57 PM
DJS's Avatar
DJS
I assume that cars without keyless entry don't have the little push button on the door handle. I didn't intentionally buy keyless entry (it was part of one of the packages I got), but I really like this implementation.
Old Apr 10, 2017 | 05:27 PM
ioneabee's Avatar
nope - push button as all the others - it just means that you have to use the key fob button to unlock the door - you can't push the recess on the door handle to close it nor the opposite way round
Old Apr 10, 2017 | 06:11 PM
UC3's Avatar
UC3
...it is odd that is even an option of this level of an automobile.
Old Apr 11, 2017 | 11:05 AM
drmerc's Avatar
I think you're right. I didn't know it was a option.
Old Apr 11, 2017 | 02:54 PM
Mueller's Avatar
The weird part is that Jaguar had to take the extra time to write additional code for those people not willing to pay for the keyless entry.
