Draining Gas
Old Jan 22, 2025 | 06:53 PM
randyb's Avatar
Default Draining Gas
Does Jag use any theft determent in the fill pipe?
I need to drain my tank as car has been sitting 10 months.
Old Jan 22, 2025 | 07:27 PM
lizzardo's Avatar
Pretty sure there's nothing to prevent siphoning. I had to have my filler neck changed for the fuel-shutoff problem when filling, so expect it's a straight shot.
How full is the tank? If actually full, you'll have little condensation. If low, you could add some "gas dryer" and then a few gallons of fresh, then go straight to a station to fill up.
Old Jan 23, 2025 | 01:24 PM
RGPV6S's Avatar
Every new car I have had for at least the last ten or 15 years has had some sort of check valve or anti siphon device in the filter neck that will not allow even a 1/4" siphon pipe past it. I don't even try to siphon gas anymore because of this.
Old Jan 23, 2025 | 04:52 PM
DMeister's Avatar
I guess you didn’t treat the gas with stabilizer?
Old Jan 24, 2025 | 07:10 AM
Carbuff2's Avatar
Have you tried starting the engine?
Yes, 10% ethanol gasoline will START to degrade after 3 - 6 months, but that doesn't mean it is totally 'bad'. If the 10-month-old gasoline allows the engine to start, you could add a stabilizer at that time, fill the tank with 'fresh' stuff, and be on your way. best to drive it and 'slosh' the fuel around.
If the tank was almost full when parked as is often recommended during winter 'sleep', there is less chance of degradation, (phase separation, look it up)
Ship
Dec 5, 2023 02:15 AM
flyrr100
Jul 30, 2023 06:50 AM
gtjoey
39
Aug 30, 2016 06:02 PM
ukdeluded
22
Apr 2, 2016 09:00 AM
Holein1
May 26, 2012 08:31 AM
