Dual pulleys - tune - pushed hard on street - some codes?
Old May 19, 2018 | 11:15 AM
John Jones's Avatar
Banned
Default Dual pulleys - tune - pushed hard on street - some codes?
Finally got a check engine light after 300+ miles when pushing it hard on the street. The codes are as follows:
P0304 - Misfire Detected in #4 Cylinder
P1315 - Persistent misfire (one cylinder identified and injector switched off)
P2169 - Exhaust Pressure Regulator Vent Solenoid Control Circuit/Open
U0447 - Invalid Data Received From Gateway 'A'
U0010 - MEDIUM SPEED CAN COMMUNICATION BUS
Im assuming the U codes are from the tune, and no big deal. Any ideas from the forum gurus before I start throwin some parts at her? Thanks guys!
Old May 19, 2018 | 01:55 PM
Unhingd's Avatar
Whose tune do you have?
Old May 19, 2018 | 01:58 PM
John Jones's Avatar
Banned
Velocity AP
Old May 19, 2018 | 02:12 PM
Unhingd's Avatar
Originally Posted by John Jones
Velocity AP
Check with Chris@VAP before doing anything else. They may need to adjust the tune for you. Clear the codes and try to re-create the conditions that throw the CEL. That will help them figure it out.
Old May 19, 2018 | 02:59 PM
ndabunka's Avatar
Do NOT "discount" the codes. They are telling you something IMPORTANT! Perhaps it's pre-mature detonation due to not having replaced the stock spark plugs with a set DESIGNED to run colder. The ECM switching an injector off could also be indicative of an injector failure, perhaps? I do know that Jag has replaced some injectors for others under warrantee
Old May 21, 2018 | 12:03 PM
John Jones's Avatar
Banned
Anyone know where the exhaust pressure solenoid is located on a 5.0L?
Old May 22, 2018 | 11:18 AM
Itismejoshy's Avatar
john johns did you do colder plugs with the pulleys and tune? its been mentioned, the stock coils/plugs will misfire when pushed hard under load. Possible easy fix?
Old May 22, 2018 | 02:01 PM
sgvkirbster's Avatar
I’ve considered also doing the smaller pulley. But it seems to be more risk than reward. I’ve already went 1 unit colder on my spark plugs. Don’t know if I should do it or not.
Old May 22, 2018 | 04:55 PM
John Jones's Avatar
Banned
Yes, I did the one step colder VAP plugs and gapped them properly.
Ive reset all the codes. Going to see if I can get cylidner 4 to misfire when pushed hard under load again - and try a new coil there.
Old May 31, 2018 | 08:40 AM
John Jones's Avatar
Banned
Ok, I replaced the coils on cylinder 3 and 4 with OEM Jaguar units. Took it back out. At super high RPM on the highway, its still misfiring on 3 and 4, and now says cylinder 1 as well. As soon as I pull over and restart, its fine. Is it related to a tune issue, or maybe module or control board? Seems like a resistor is bad, or the control module voltage may be screwing it up.
Old May 31, 2018 | 12:08 PM
Don1954's Avatar
All was fine before you Vapped it right?
Old May 31, 2018 | 07:33 PM
John Jones's Avatar
Banned
Yup. I sent an email this morning. Hopefully they have an answer soon.
Old Jun 15, 2018 | 03:34 PM
XJ-SS's Avatar
Injectors can't keep up and going static maybe?
How many miles on the injectors?
Old Jul 10, 2018 | 02:08 AM
ss23's Avatar
Any update on this? I've installed the crank pulley with the stock V8 spark plugs (my guess is that they are 44k miles old) and am getting misfires with the car going into limp mode (Restricted Performance mode, no CEL though).
Am wondering if its the spark plugs or any other issue. Will try and replace the spark plugs in the next couple of days.
Old Jul 10, 2018 | 07:57 AM
stmcknig's Avatar
Do you have the stock tune or a modified one ?
Old Jul 10, 2018 | 09:36 AM
ss23's Avatar
Whoops, should have mentioned, I have the crank pulley, Eventuri intake, 200 cell cats, according VAP tune and Aquamist water injection system.
Edit: also seem to persistently have an "air flow too high" code stored in the ECU. Not sure if it's improper installation of the Eventuri intake or an air leak in the Aquamist system
Old Jul 10, 2018 | 11:08 AM
Gibbo205's Avatar
I'd refit stock air box and remove the aqua mist, if it then runs fine, you know the issue is not the tune, but the hardware.
Old Jul 10, 2018 | 11:05 PM
Unhingd's Avatar
+1. With both pulleys, VAP tune, and pushed hard, I have no issues at 24,00o miles.
Old Jul 14, 2018 | 08:58 AM
John Jones's Avatar
Banned
It was indeed the VAP tune. Too much timing uptop. Got with stuart and chris, and chris had me a new tune in a day or two. Pulled a few degrees of timing from up top, as it was pushing the stock coil packs too hard, and then shutting down the fuel injector, which is causing your limp mode. I replaced ALL my coils with brand new OEM limits, but it made no difference.
When I take it to the dyno, I will log it to see the absolute max we can push a V8 w/ no cats & dual pulleys. If you havnt changed the plugs for the additional boost, you absolutely should.
Old Jul 14, 2018 | 03:30 PM
ss23's Avatar
Thanks for that, was very helpful. I have isolated my issue now to the Aquamist system, I think there's a leak somewhere in the rear leading to the air flow issue. I did change the spark plugs (went with the V6 ones) but not sure if they made any significant difference, don't seem to have done.
I'm really interested to see your logs and how much power you can make out of the V8! What mods do you have barring the dual pullies and tune?
