Electronic Oil Dipstick - Fail-safe Ideas
Old Nov 13, 2017 | 10:08 PM
JagRag's Avatar
Default Electronic Oil Dipstick - Fail-safe Ideas
Electronic Oil Dipstick, Fail-safe Ideas
As the title says, please post your ideas for a secondary `fail-safe` oil level measure.
Has anyone tried to send a traditional dipstick down the oil siphon chute under the oil-fill cap? Once a base-line measurement is taken a mark on the dipstick can be made when you can confirm that the oil is at the full mark and another when you know you are down one quart (or one litre) of oil. Obviously this dipstick would need to be cleaned and stored separately outside of the engine when not in use.
Any thoughts? Any other ideas?
Old Nov 13, 2017 | 10:39 PM
OzXFR's Avatar
Already discussed in some detail on the XF forum although no updates for a while, see here: https://www.jaguarforums.com/forum/x...-level-190570/
Old Nov 14, 2017 | 12:32 AM
15FTypeR's Avatar
Maybe find a pressurized oil line somewhere and add a fitting and a pressure sensor.
Old Nov 16, 2017 | 01:58 AM
Misujerr's Avatar
The idea of the plastic tube sounds promising. But I suppose it could stretch and render the reading inaccurate?
Old Nov 16, 2017 | 09:15 AM
DJS's Avatar
DJS
You'd have to figure out how to calibrate it too, probably by starting with it empty, then add a fixed amount of oil and see where it reads. Unlikely that the measured depth relates linearly to how much oil is there.
