Engine hitting bonnet
So today I was at a stop light and thought, there not one around so I'd turn off traction control and do a burn out take off. Well, just seconds into it and the engine hit my bonnet and pushed it up some, like a few inches....YIKES! I'm wondering if I broke a motor mount, or is the engine supposed to have that much travel? I opened the bonnet and noticed my mina gallery intakes were elevated some, so I loosed up the clamps and pushed them down about a half inch. However, I'm not sure if thats the fix.
Has anyone on here had this issue? A possible broken motor mount? Gonna put it in the air later this week to swap my wheels so I can crawl under and look then. |
Your suspicion has to be correct - motor mount.
Maybe you triggered the pedestrian protection system?
The twin airbags under the hood up the windscreen end which are meant to go off and push the rear of the hood up a few inches in the event of a front on pedestrian collision. This system is known to be problematic with many instances on XFs and a few on F-Types of false deployment when hitting a pothole etc. Easy enough to check and see if those airbags have gone off. |
Originally Posted by OzXFR
(Post 2365294)
The twin airbags under the hood up the windscreen end which are meant to go off and push the rear of the hood up a few inches in the event of a front on pedestrian collision. This system is known to be problematic with many instances on XFs and a few on F-Types of false deployment when hitting a pothole etc. Easy enough to check and see if those airbags have gone off. My vote is for a broken motor mount... |
Originally Posted by sov211
(Post 2365314)
Good idea, but almost certainly not the cause because the US and the Canadian cars do not have the pedestrian protection system. We do not value the lives of pedestrians.
Originally Posted by Stuart Satter
(Post 2365103)
Has anyone on here had this issue? A possible broken motor mount? Gonna put it in the air later this week to swap my wheels so I can crawl under and look then. A photo speaks a thousand words.... |
Why would an engine mount break on a 5 year old car?
I'm going with motor mounts! :icon_shrug:
(Post 2365316)
Thanks for that, I had forgotten that North American cars are not saddled with that idiotic system!
Those Volvos are very dangerous!!
Originally Posted by newskatercat
(Post 2365599)
In the Old Days, we'd check mounts by opening the hood, applying the brake, and then giving it some gas while in gear and looking for excessive engine movement. For the Saab 99s it was usually the front mount (under the radiator). The F-Type doesn't have one of those ;^) |
Originally Posted by lizzardo
(Post 2365750)
I'm sure they're hydraulic mounts. It's not unheard of for them to leak. I think a visual inspection would reveal that, but honestly, I can't think of anything else it could be.
Yeah, no air bags in the US in the bonnet. I'll put it up in the air in a day or so and crawl underneath. I had my wheels re powder coated black from brushed bronze. and will be putting them on. Tired of cleaning brake dust all the time.
Does anyone know of any performance upgrades on motor mounts? I think the increase of Torque did this and want stronger parts. Maybe even an added torque brace availability? |
Looks like the Engine Mounts ( AWD - T2R23625 - L & R - RWD - C2D2745 - L & R) ) are challenging to get to/replace. I have not seen any upgraded versions anywhere, but perhaps someone else has?
I have posted a link to the R and R Process on my Cloud Drive below...and a picture of what they look like below. Not very impressive looking. Will add this to my DIY Thread as well. (Note this is for V8 AWD). RWD will be similar. DC LINK to Procedure https://cimg1.ibsrv.net/gimg/www.jag...0f2fc8a13e.jpg |
Thanks for the info. Looks like a pain in the ass to do this. Guess I'll be swapping out the high pressure fuel pumps when I do this too. Its only a matter of time before they shit the bed as well at 65K miles.
Originally Posted by Tel
(Post 2365897)
Or easier still, put the engine on first gear, and rock the car bak and forth to see any flex....Doh, sorry forgot you were nearly all autos back then! ( The only cars that had autos from memory in the UK then were posh cars like Bentley, Rolls!).
(Post 2365974)
DC |
https://cimg6.ibsrv.net/gimg/www.jag...91d1cd6fd.jpeg
https://cimg7.ibsrv.net/gimg/www.jag...a4a4f64f7.jpeg https://cimg8.ibsrv.net/gimg/www.jag...b09eef0fd.jpeg Just as suspected. Drivers side mount was broken. Also replaced the trans mount as that was cracked in half. Passenger side mount intact. |
(Post 2375038)
https://cimg7.ibsrv.net/gimg/www.jag...a4a4f64f7.jpeg https://cimg8.ibsrv.net/gimg/www.jag...b09eef0fd.jpeg Just as suspected. Drivers side mount was broken. Also replaced the trans mount as that was cracked in half. Passenger side mount intact. Did you change them yourself? If so, how bad was it? Thanks for posting the pics. DC |
Originally Posted by Therock88
(Post 2375061)
Wow...That sucks. Was the little rope/string broken off as well? or did you take it off?
