Euro Amp Headgaskets
Old Jan 1, 2025 | 04:38 PM
randyb's Avatar
Question Euro Amp Headgaskets
With the warpage issue on the aj126, thinking about using their 4 layer gaskets, has anyone used them and what was your expience?
Old Jan 2, 2025 | 03:12 AM
Adam Deermann's Avatar
Hi,
Warpage comes from overheating, it is relaxation of the aluminium.
The only good way is to make it flat again, that means to the workshop with the heads and if so, the block.
Euro Amp head gaskets seems like good head gaskets to me, must be a regular brand.
regards,
Adam
Old Jan 2, 2025 | 02:39 PM
Stuart@VelocityAP's Avatar
I would recommend Cometic.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Jan 3, 2025 | 10:58 AM
randyb's Avatar
Thanks Stuart
Old Jan 3, 2025 | 11:02 AM
Thanks Stuart
BTW - we are working on confirming that the head studs we developed for the V8 are compatible with the V6. Might be something to consider on a rebuild.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jan 3, 2025 | 11:03 AM
randyb's Avatar
Well, Cometic only makes headgaskets for the V8 and not the V6, so that sucks!
Old Jan 3, 2025 | 11:07 AM
Sorry, I thought they made V6 as well. Bet you they would.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jan 3, 2025 | 06:29 PM
Lothar52's Avatar
Never knew about a warping issue. just coolant and timing chain...both of which I've had redone at 37k miles - have an article or a discussion about this issue I can read up on?
Loth
Old Jan 3, 2025 | 07:40 PM
OzXFR's Avatar
Loth
The theory is that if/when a coolant pipe bursts and much of the coolant is dumped and the driver ignores the warning signs and keeps driving, the engine will over-heat badly enough to blow a head gasket and/or warp the head(s) and/or the block.
A small number of reports of this happening but way short of an epidemic.
Old Jan 4, 2025 | 12:00 AM
Lothar52's Avatar
Aaahh... the complication of the coolant pipe issue and the overheating. I thought there was something else going on new.
Old Jan 4, 2025 | 03:50 AM
randyb's Avatar
From what an indy shop told me, if you do not undo the heads correctly, they can warp. You have to loosen the bolts in stages to prevent the warping.
Old Jan 8, 2025 | 09:38 PM
lizzardo's Avatar
Things should be disassembled correctly, but the in my experience warped heads have always been from overheating. I remember one of my motorcycles' service manual noting that cam bearing caps need to be loosened in order to prevent breaking the hollow camshafts.
Old Nov 24, 2025 | 09:13 AM
monsoon's Avatar
I don't see the aj126 gasket on their site... only the v8. am i missing somthing?
Old Nov 24, 2025 | 09:29 AM
randyb's Avatar
Wink
If you noticed my post after Stuart, I mentioned they do not make a v6 gasket.
Old Nov 24, 2025 | 09:42 AM
RoverJoe's Avatar
Community Influencer
OEM gaskets are fine, the issue comes from the engine being particularly sensitive to overheating, worse on the V6 vs the V8. Just my opinion but I believe it has to do with the structure of the block, the modified v8 block used on the v6, that causes heat to build up unevenly when they do overheat. It's very common for an overheated V6 to no longer be flat on the heads or block, and as machining is against factory workshop process, we have to replace. I have opened them up and found no warpage, installed new gaskets and they were fine. But the issues always stem from overheat, not a gasket failure itself.
One downside to modern MLS gasket technology, is they are extremely intolerant of poor sealing surfaces. The two faces need to be perfectly flat and clean, and then the gaskets will take all kinds of abuse. Once the surfaces are not flat, the gaskets don't work at all. There is no wiggle room.
Scout123
Jun 20, 2024 09:00 PM
SecretSupercarOwner
Non-Jaguar Vehicles
Jun 6, 2020 09:11 AM
omgimali
Jun 3, 2020 04:39 PM
WesSide
Audio/Visual Electronics
Jun 1, 2010 05:32 PM
simplesimon2
May 23, 2008 09:47 AM
