Flat tire Question
Old Jun 13, 2022 | 01:22 PM
bluejaag's Avatar
Default Flat tire Question
Hi all, running the Michelin PS4s, staggered 255s in the front and 295s in the rear on a R AWD. Back left has gone flat after being at 37psi yesterday.
Bought from Costco couple years back (February 2020), since put on 10k miles. Not sure if they're still under warranty.
Should I flatbed it to Costco to deal with warranty? Or would Discount tire also work for the warranty?
For the staggered setup, does Michelin still recommend/require they're rotated side to side?
Old Jun 13, 2022 | 02:33 PM
kb58's Avatar
Call them to get a fast and accurate answer instead of asking here and waiting around for answers!
Old Jun 13, 2022 | 04:06 PM
Valerie Stabenow's Avatar
Default Here's the link to the Michelin warranty page
https://www.michelinman.com/auto/assistance/warranty
Old Jun 13, 2022 | 05:28 PM
uncheel's Avatar
Failure to rotate tires cuts the Michelin mileage warranty in half, but it shouldn't impact your repair coverage at Costco. If the damage is in the tread area, about any place can plug it and the cost is minimal. I carry a plug kit in the trunk (recommended & cheap), because you're not always near a tire store. But, if the damage is anywhere close to the side/sidewall, you're probably looking at a new tire. If you can get the tire to hold enough air to drive to Costco, then go for it.
Old Jun 13, 2022 | 07:53 PM
OzXFR's Avatar
The first thing to do is figure out why it went flat.
Puncture?
Leak at the rim?
Faulty valve?
Cracked rim?
Take the flat to any tyre shop and they will be able to figure this out in a jiffy and probably fix it on the spot for minimal $.
Then if it is something more serious such as a tyre fault you can consider a warranty claim.
Edit - forgot to add, nothing is achieved by rotating MPS4S side to side, the inside and outside don't change and shouldn't be changed anyway. They have "inside" and "outside" written on them.
Old Jun 13, 2022 | 09:02 PM
CJSJAG's Avatar
My undertsanding is that (all) tire mnufacturers cut their warranty in half if your vehicle has different size front/rear tires.
The "logic" may be that it is not possible to rotate tires in a meaningful way - of,course it could just be that they are just using that excuse to cheap out on their warranty
Old Jun 13, 2022 | 09:16 PM
Borbor's Avatar
Warranty only applies to manufacturing fault such as delaamination. If it is just a nail it’s got nothing to do with Michelin. Maybe Costco has their own tyre warranty for punctures on tyres bought there if you are lucky.
Old Jun 13, 2022 | 09:46 PM
uncheel's Avatar
Yes, one of the nice benefits of Costco is that all their tire sales come with road hazard warranty.
Old Jun 14, 2022 | 06:22 PM
bluejaag's Avatar
Thanks all! Found a nail and apparently in sidewall. Drove her up onto flatbed this morning. Was wrestling with deciding to go to Discount Tire (15min away) or Costco (about an hour) away where I bought them. Convenience won out.. hope I didn't give up a free covered replacement!
ksurfer2
Sep 7, 2016 09:28 PM
tiger4366
Sep 22, 2015 09:20 PM
Jag#4
Jun 2, 2015 07:20 AM
XKR-NC
Dec 21, 2014 10:12 AM
XJcat
General Tech Help
Sep 5, 2010 09:10 AM
