does anyone have the actual document with the front disc thickness specification (380mm steel brakes v6s)
in my manual pdf I can only find the spec for the CCD variant (shown)
my brake thickness is 34.5mm which I think is in spec- having an argument with a garage about a road worthy certificate.
The specified minimum thickness for the 380 mm front iron brake discs is 34 mm so at 34.5 you are getting close.
That said the specified minimum thickness is ridiculously conservative at only 2 mm less than new thickness and I would hazard a guess that those very beefy front discs would still be perfectly OK at down to 32 mm thick. Of course at 32 mm an insurance claim could be an issue!
