Gearbox Fault / Shifts Out of Drive / Can't Shift Into D or P or R
Old Jan 29, 2014 | 08:26 AM
New2Jag's Avatar
Default Gearbox Fault / Shifts Out of Drive / Can't Shift Into D or P or R
I have had this issue three times now, figured I would ask around, see if anyone else has had the same issue. Not concerned yet... could just be a combination of a few things.
Here's what I got:
Started car, put it in reverse... car died. Drive indicator on the dash was flashing (R). Tried to put it in park. Could not. Tried to put it in drive. Could not. Turned car off and back on - worked fine.
Same thing a day later. But when I turned the car back on, it said in yellow in center dash (Gearbox Fault). Same thing. Couldn't put it in drive or reverse. Cycled power on car three times, nothing. Fourth time was the charm.
Anyone else with similar issue?
Old Jan 29, 2014 | 09:25 AM
tlrominger's Avatar
I've had mine for about 5 days now and haven't had any problem with the gearbox. But I'm just now over 200 miles though
Old Jan 29, 2014 | 09:28 AM
themacs's Avatar
Had mine for a month and 300 miles. No gearbox issues.
Old Jan 29, 2014 | 10:02 AM
Quibbs's Avatar
You need to take your car in. That should not be happening.
3000 miles, not a single issue.
Old Jan 29, 2014 | 10:11 AM
apexhunter's Avatar
New car under warranty, why waste time on a forum. Its not normal. Just get it to the dealer ASAP. For the record, almost 4k miles no issues like that.
Old Jan 29, 2014 | 12:44 PM
amcdonal86's Avatar
If it's anything like all the other modern Jaguars, I'm going to guess it's something to do with the battery...
Old Feb 14, 2014 | 04:26 PM
technabob's Avatar
I'm not sure if this is related to this, but you might want to check with the Jaguar dealer and mention this service bulletin to see if it is the same problem.
JTB00324NAS1 - Transmission Stuck in Park on Start Up
Old Apr 20, 2014 | 01:32 PM
Philipintexas's Avatar
4,700 miles and I encountered the "Transmission Fault" situation. Cycled the start/stop several times and was able to eventually exit my garage . I'm having another re-curring "brake" amber warning so will be headed to the dealer next week to resolve a few break-in glitches. Sure hope these are isolated glitches.
Old Apr 23, 2014 | 04:18 AM
Lothar52's Avatar
They should run a complete diagnostics on your car... It should be found out WHY this is happening and the part(s) replaced... I dont even have a F-Type and this is NOT normal. The F-Type is more advanced then my XK's and I have had nothing of the like with my gearbox. Its got to be something and it needs reported immediately!!!!!
Old Apr 25, 2014 | 12:11 PM
I just got mine back from the dealer, there was a "failure to communicate" with the gear-box controller, they corrected the problem.
Old Apr 28, 2014 | 07:53 PM
cjp's Avatar
cjp
They used to say that Rolls Royces did not break down, they "failed to proceed". Sounds like a bad connection somewhere. Glad it was an easy fix.
Old Sep 27, 2014 | 01:47 PM
daver1951's Avatar
Default Same problem with gearbox fault
I just had the same problem today 9/27/2014,with my 2014 Ftype. Turned car off. Got back in and started it and couldn't get it out of park. Repeated process. Repeated again and it worked ..Each time it said gearbox fault with the triangle warning sign. Will contact dealer and take in.
Old Sep 30, 2014 | 07:32 PM
daver1951's Avatar
Contacted dealer today and they said there is a bulletin out that requires a download to correct the problem. Taking car in on 10/2. Will post outcome
Old Jun 19, 2015 | 10:57 AM
Anthony Cappuccio's Avatar
Default gear box fault f-type
car been into shop five times for gear box fault....keeps stranding me places in shop today for hopefully a fix
Old Jun 19, 2015 | 10:58 AM
same thing since november they are changing one part at a time
Old Jun 19, 2015 | 10:59 AM
got download didn't help
Old Jun 19, 2015 | 11:00 AM
been to dealer six times no fix
Old Jun 19, 2015 | 11:13 AM
uncheel's Avatar
FWIW, I had a gearbox fault a couple of months ago. The car started, but wouldn't shift into any gear. Fortunately, I was at home and not in a bind. I restarted/retried a couple of times - same issue. However, about 30 minutes later, every worked. Nonetheless, I called to dealer. They said there was a bulletin to replace a brake pressure switch which could cause the problem. I was in and out in 30 minutes. I haven't had the fault recur. Since you've had several runs at it, I'd expect it would have been in the string of attempts your dealer has tried. But, just in case....
Old Jul 6, 2017 | 11:06 AM
Jason Spencer's Avatar
Default gearbox fault issue as well on f type at 11k
I have this happen once about ever 100 starts and each time it takes more attempts of turning the car off and back on to get it to cease. 2 Trips to the dealership and no fix yet however this last trip they seem to have done something to attempt to fix it which is causing the car not to shift in automatic half the time. Forcing me to get very comfortable with paddle shifting.
Kind of amazing how some cars can sense when the warranty is coming to an end. Mine ends this month and the for the first time I would have to say its becoming quite unreliable.
Old Jul 6, 2017 | 05:11 PM
jaguny's Avatar
Anyone have the TSB with vin range affected by this problem?
