Group Buy: (4) 17mm hubcentric adapters/spacers
Old Aug 13, 2016 | 05:09 AM
  #241
Tel's Avatar
Tel
Default To grind or not to grind
I'm not convinced about the Jag studs being different lengths, I think it is down to the 'pocket' size on the particular style wheel.
The blades I have measured at over an inch, maybe we could see someone with another style wheel measure the pocket depth as a comparison?
Old Aug 13, 2016 | 06:25 AM
  #242
cptslow's Avatar
I didn't check the pocket depths, but the tech who installed the spacers measured the studs on the wheel hub to make sure he wasn't going to have a problem and the lengths are in fact inconsistent. It may be a combination of the two things though, where the space available inside the wheel makes the stud length irregularities irrelevant. I find it a little hard to believe that the same wheels (Tornados) would be inconsistent as opposed to the studs, which would seems a cheaper and less "critical" (from the standpoint of slight irregularities) piece of the car.
Old Aug 13, 2016 | 12:36 PM
  #243
polarisnavyxj's Avatar
Default Guys, we are overthinking this whole thing
It's a one time trim that takes minutes if need be.
Regardless of what the cause is and whether you need to or not, the point is this...
Test fit your wheels and if you don't get a clean seat, do the two minute trim.
We'll put in more energy trying to diagnose the "why's" when the focus should be the "If and How's".
It's such a simple fix that if it needs doing, the tool required is a $29 angle grinder @ Home Depot. If you don't already have one in your toolbox, it'll be worth every penny moving forward.
Old Aug 13, 2016 | 12:38 PM
  #244
cptslow's Avatar
Test fit your wheels, if you don't get a clean seat, do the two minute trim.
We'll put in more energy trying to diagnose the "why" when the focus should be... the "If and How".
It's such a simple fix that if it needs doing, do it.
Agreed. I was simply pointing out that the above poster who suggested that Tornado wheels may all be problematic, isn't correct. It's more 'luck of the draw" as it seems.
Old Aug 13, 2016 | 02:36 PM
  #245
Tel's Avatar
Tel
It may be the end of the stud that has no thread on it which appears to be "peened' slightly. The threaded portion I'm positive would need to be consistent as each car can be specced from new with a whole host of wheels and they all need to fit of course.
The pocket are milled out on a CNC machine once the wheels have been cast, so I would imagine they would be within a few thou of each other.
I had my wheels off again for a final torque, and measured all the JLR studs and Lenny's and they are all the same....maybe you are right...it's luck of the draw!
Old Aug 13, 2016 | 07:26 PM
  #246
Mbourne's Avatar
While the studs may or may not be uniform (it really doesn't matter) the different wheel designs have different pocket depths depending on model. Cyclones are too shallow so grinding all studs will be required. The other wheel types vary.
Old Aug 14, 2016 | 11:20 AM
  #247
Dremorg's Avatar
Does a wheel alignment need to be done after the spacers? My car seems to need one now after the spacers were installed.
Old Aug 16, 2016 | 07:44 PM
  #248
Unhingd's Avatar
that should not be the case.
Old Sep 7, 2016 | 03:42 PM
  #249
Seb_CH's Avatar
just mounted Lenny's adapters on. Very happy with the result. I do however agree that it would need to be combined with a set of lowering springs for a perfect stance. Will ponder my options..
Old Sep 7, 2016 | 05:15 PM
  #250
Unhingd's Avatar
Go with the Velocity AP springs if you have a steep driveway approach. Otherwise the H&Rs offer the most aggressive looking stance. ( and handle really well. )
Old Sep 7, 2016 | 05:59 PM
  #251
Seb_CH's Avatar
thank you Unhingd. Not steep driveway entrance but I think I nevertheless prefer the mild drop of the Velocity springs. I just need to make sure they come with the necessary certification papers in order for them to be properly registered on this car in Switzerland. They can be pretty tedious with such mods over here. I will contact V. AP
Old Sep 26, 2016 | 06:22 PM
  #252
NiteriderSC's Avatar
are sets still available?
Old Sep 26, 2016 | 06:27 PM
  #253
Unhingd's Avatar
Motorsport Technology
775-351-1000
Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Tech
Old Sep 26, 2016 | 06:30 PM
  #254
Has anyone used these on Vela wheels?
Old Sep 29, 2016 | 11:28 AM
  #255
Mpowerr's Avatar
Has any of you used these on a car with carbon ceramics? I ask because the face of the rear aluminum hats are not flat, only the portion where the wheel backpad sits is. So if the diameter of the spacer is exactly that of the wheel backpad then it should be fine.
Can someone that has installed them take a close up pic of the spacer through the spokes of the wheels once mounted.
Old Oct 9, 2016 | 01:26 AM
  #256
DJP's Avatar
DJP
Are there any 17mm ones still available?
I would like to buy some for a 2014 Ftype v8 s with the
blade wheels.
Old Oct 9, 2016 | 06:24 AM
  #257
Unhingd's Avatar
blade wheels.
Call them:https://www.jaguarforums.com/forum/f...3/#post1541921
Old Oct 12, 2016 | 04:04 PM
  #258
SanDiegoJAG's Avatar
So I am worried that the 17MM adapters and then adding 305's in the back will be too wide and sticking out. I personally need to error on the side of not enough width. Won't the wider tire stick out another 5mm (5mm on outside, 5mm on inside). I am considering going with 15mm in front and 10mm in back therfore the end result would be 15mm in front and 20mm in back. Am I being too crazy? I am an orthodontist and 5mm is HUGE in my business.
Old Oct 12, 2016 | 06:14 PM
  #259
Many know much more than me but I'd say you'd be ok as long as there's not a drop involved. I've instlled my 17mm and there's room for bigger tires using the eyeball test.
Old Oct 12, 2016 | 06:36 PM
  #260
Unhingd's Avatar
+1. Not much room left over with the 15mm adaptor/305 tire/1.3" H&R spring combination, but without a lowering you can easily fit a 305 tire and 17mm spacer.
