Group buy Pt2: 2pc wortec rotors for steel high perf brakes on f-type
Old Nov 5, 2019 | 10:56 AM
Jaggyx's Avatar
Originally Posted by watson6505
Ive got 20" cyclones in black, which probably tip the scales at 40-50lbs (20-22kg)
They can't be that heavy. That'd be insane. Probably 32+ lbs for sure though. A 20 inch forged wheel should run low 20's.
Old Nov 5, 2019 | 11:03 AM
watson6505's Avatar
Originally Posted by Jaggyx
With BC Forged, you can get fully forged wheels just south of $4k... I'd argue if you're going to spend 4k for looks and unsprung weight savings, a fully forged wheel is probably a good place to start if you don't already have some lightweight wheels.
modular or monoblock recommended?
Old Nov 5, 2019 | 11:24 AM
WayneB's Avatar
I'd be in for a set of,
Super Performance Brakes: 380/376
if this deal goes through.
Wayne B.
Old Nov 5, 2019 | 11:30 AM
Jaggyx's Avatar
Monoblock will be the lightest.
Old Nov 5, 2019 | 11:47 AM
watson6505's Avatar
Wayne B.
Wayne - this particular group buy is for the high performance size wortec rotors...the super performance group buy was in 2018 I think. However, you are in luck that you can get the super performance without a minimum purchase. The only reason we need 10 is because the high performance rear rotors are smaller than the super performance...which means wortec has to do R&D and invest to get those made for us. If we get at least 5 people interested in the fronts (since high and super are the same rotor) we can get a volume discount. I think we are at 3 potentially that would like the fronts. You could also add the rear to your order but benefit from the discount on the fronts if we get to 5+.
Old Nov 5, 2019 | 01:26 PM
BruceTheQuail's Avatar
Bruce - I've been looking for forged wheels online and I cannot seem to find 20", correct bolt patters, and rim dimensions. The ones that I do find are typically 2000k+ EACH. Any links you can provide that sell 20" and I can reuse my brand new 20" MPSS please share.
Jaggyx has made a suggestion for 20"s, I went with Vorsteiner 21's which imported to Oz, at our exchange rate (your buck is worth more than ours) came in at $6K odd with Michelin PSSeses on them. I'd have though around $4K in your money with tyres on.
Old Nov 5, 2019 | 02:49 PM
watson6505's Avatar
do any sites list the wheel weights for the vorsteiner or VS or BC forged or even the stock wheels? I have had zero luck finding the weights of different wheels. There are some nice wheels out there under 1k each, but I cant purchase without knowing the weight savings...I like the wheels I have but I know they are heavy.
Old Nov 5, 2019 | 03:13 PM
  #28
Jaggyx's Avatar
I'd call BC Forged. Their HQ is in Florida. Each design has it's own weight, obviously.
Old Nov 5, 2019 | 03:30 PM
I could never find it either, here is a thread where someone else weighed their 19 inch Vorsteiners (they come in 19's and 21's) https://f80.bimmerpost.com/forums/sh....php?t=1092326. As you will see under 23 pounds each. Here is a weight chart for Michelins https://tiresize.com/tires/Michelin/...uper-Sport.htm. I suppose though that in my case I got much wider wheels as well to fill out the wheel arches. That would have taken weight back up a bit, though it still feels much lighter than OEM
Old Nov 5, 2019 | 03:52 PM
  #30
watson6505's Avatar
bummer that they dont make 20s...that ups the total cost about 1200 for new rubber.
Old Nov 5, 2019 | 09:02 PM
  #31
Unhingd's Avatar
+1. The VS03 9.5” & 11” wheels are 21.8 & 24.4 lbs (exactly 10lbs lighter each than Gyrodynes) and came in around $2400. VS also offers any size & offset
Old Nov 5, 2019 | 09:10 PM
  #32
watson6505's Avatar
Thank you...looking at possible VS02/VS08/VS12...trying to mirror the Vorsteiner V-FF 103's but not have to get 21's
Vorsteiner V-FF 103
VS02
VS08
VS12
All very nice in one of the shades of black to go with my black F
Old Nov 5, 2019 | 10:16 PM
  #33
Jaggyx's Avatar
VS is a great option, but last time I checked, their wait times were 12 weeks. I went with BC Forged because I'm not patient enough to wait 12 weeks. BC's are about 4 weeks from order to door.
Old Nov 6, 2019 | 04:56 AM
  #34
Unhingd's Avatar
When I placed an order for my car (MT) in November 2014, I had to wait 7 months for it to arrive. 3 months for wheels didn’t seem so bad,
Old Nov 6, 2019 | 07:45 AM
  #35
watson6505's Avatar
I'm not all that patient either, but the car will soon be going away for a few months to hibernate so the timing might be perfect. I'd even say Id like to drive with the tune/pulley after that is done (spring) then see if there was an improvement in performance/handling going from tune/pulley to lighter wheels. Maybe by then we will even have 10 people interested in high performance wortec rotors!
Old Nov 6, 2019 | 11:50 AM
  #36
Ltrain925's Avatar
So I just got a reply for wortec, they will allow me to purchase just the front rotors, as I’m not interested in rear (cost reasons). So put me down on the list. I don’t mind waiting for a month or 2 because I’m buying new rims, looking at signature sv701 wait time is 4-5 weeks there exactly 10lbs lighter per rim but those VS rims are a nice price, 2400$ vs $3500. 12 weeks wait! I’m gonna call and confirm that.
Old Nov 6, 2019 | 11:55 AM
  #37
watson6505's Avatar
I will keep a running list of people that are interested in front or rear or both. Once we give it another couple weeks we will see where we are and make a decision at that time if we have an opportunity for a group buy. If not, I guess we will order what we want on our own (of what they already have which is super perf ONLY front/rear)
Confirmed interest:
1. watson6505 (Myself)
2. Ltrain925 (Front Only)
3.
Old Nov 6, 2019 | 11:56 AM
  #38
Jaggyx's Avatar
Not bad at all for a fully forged wheel set.
Old Nov 6, 2019 | 02:24 PM
  #39
Unhingd's Avatar
Reducing the unsprung weight by 80 pounds (all rotational mass), after the tune/pulley has been in effect for awhile , definitely improves the perceived acceleration.
Old Nov 6, 2019 | 08:48 PM
  #40
watson6505's Avatar
is it wrong to not want to buy wheels that you might see on a tesla or a challenger or a camaro? I am seeing the VS Forged on a lot of other model cars (online that is) and I am torn between being able to find something under 9k and not pulling up to a light next to a souped up civic with the same wheels. Has anyone else struggled with this dilemma? Is the way to avoid this by spending 2k PER wheel?
