Help needed with the service menu
Old Sep 7, 2018 | 12:17 AM
Paul champagne's Avatar
Default Help needed with the service menu
Hello all,
when I first picked up the car, I checked all the gadgets and everything appeared normal as per the manual. Since then, when I check the oil level, I get the message "not available". When I check the tire pressure, I only get the prescribed pressure, the actual pressure is 0.
I only have access to the service menu when the ignition is switched on, but not the engine. I think that is normal. But I know I saw some readings last week on both the oil level and tire pressure.
Old Sep 7, 2018 | 01:14 AM
OzXFR's Avatar
I can't help you with the tyre pressures as I don't have the TPMS on mine (a good thing I reckon!) but I can help with the oil level read-out.
The handbook tells you to warm the engine up to operating temp then shut it down then wait another 10 minutes at least before you can get a reading, otherwise you get "not available".
But if you pop the hood you will get an instant read-out every time, even when cold, providing you haven't started or run the car in the last 10 minutes.
Old Sep 7, 2018 | 01:49 AM
Thanks. That is pretty much what I do. Even when I open the hood, I still get "not available"
Maybe it's the "providing you haven't started or run the car in the last 10 minutes" that I'm doing wrong. I will keep an eye on that.
Thanks again
Old Sep 7, 2018 | 06:48 AM
Paul_59's Avatar
Banned
to get the immediate (not necessarily accurate) value when the normal reading shows not available you need to
1) lift bonnet / hood
2) select oil level
3) when it shows not available, press cruise control cancel button twice in quick succession to toggle to immediate reading
tyre pressure when stationary will show recommendation in brackets and actual pressure above, when car is moving only actual pressure is displayed, with recommendation being replaced with a dash (-)
pressing cruise cancel twice again will toggle back to normal reading, as will closing bonnet or cycling ignition on / off
Old Sep 7, 2018 | 08:22 AM
2) select oil level
That might be a model year thing, as there is no way for my MY2015 to get to the service menu when the engine in running. So I would not be able to see the tire pressure when the car is moving.
Old Sep 7, 2018 | 01:23 PM
Paul_59's Avatar
Banned
on mine it's in the Vehicle information menu
Old Sep 7, 2018 | 04:09 PM
On mine as well, But the section is grayed out when the engine is running
Old Sep 7, 2018 | 04:29 PM
Arne's Avatar
+1 on my MY15 as well.
Old Sep 7, 2018 | 04:34 PM
sov211's Avatar
Paul:
This is easy and no cause for concern. The ONLY reason you are told to wait for 10 minutes is to allow time for all the oil to return to the sump in order to get an accurate reading. You do NOT need to start the engine, shut it off, and wait 10 minutes, nor go through the open-bonnet procedure.
The simplest thing is the easiest: BEFORE you start the engine in the morning, push the START button but not the brake pedal -and you already know this. Then scan through the menu; you will be able to get a reading of the oil level as well as tire pressures and so on.
your car is operating exactly as it should. You do have the owner's manual, yes?
Old Sep 7, 2018 | 05:11 PM
Originally Posted by sov211
Paul:
Hello Gregory,
thanks for the directions. That is what I'm doing and up until this week, I was getting the results you describe. But lately, I am only getting the prescribed tire pressure. The actual tire pressure remains at (0). And to get the oil level, I have to press twice on the cancel button. Even when the car is warm.
I just installed a set of dash cams and I wonder if the Bluetooth of the battery pack or the local WiFi of the cameras is maybe interfering with the RF signal of the TPMS.
Just a thought
XJcat
Jul 9, 2021 04:21 PM
veffremov
Audio/Visual Electronics
Jan 15, 2009 01:31 AM
ItalianXtype
Mar 22, 2008 08:07 PM
