How long will your battery stay charged?
Old Feb 10, 2016 | 08:43 AM
lsbrodsky's Avatar
Default How long will your battery stay charged?
Have any of you determined how long you can leave your car in the garage without a battery maintainer attached? The reason I ask is twofold. First, since I rigged up my trickle charger I have noticed that after a couple of days off the charger, my charger starts earlier in the charge cycle than it does/did with my other cars. Yes, I fully charged the battery before making this determination. Second, we leave for a couple of weeks at a time and I found that previous cars could go 3 or 4 weeks without needed a charger hooked up.
Thanks,
Larry
Old Feb 10, 2016 | 08:50 AM
Buckingham's Avatar
I left my new V6 for three weeks in the garage and it started just fine. I just bought a battery tender plus 3 Amp and hooked it up. After four hours, it still wasn't at 80% charge. Took overnight to fully charge. I do lots of short trips and the battery must have been really low but the car operated just fine. I'm going to charge it up every week now.
Old Feb 10, 2016 | 09:36 AM
ShaunPA's Avatar
my car sat a couple of stretches for 2 - 2.5 weeks while on vacation without issues.
Old Feb 10, 2016 | 10:02 AM
f-driver's Avatar
Hi Larry ,
I was interested in this question two years ago so I measured quiescent current on my car.
The result was that standby current consumption is definitely less then 20mA .
Assuming your 90Ah battery is fully charged when you store your car and you accept to
go down to half of the stored capacity you can go for approx. 3 month .
But be careful . If you unlock/lock the car with your key , a lot of electronic devices "wake up"
and current consumption increases dramatically . Current consumption remains high after locking
the car for some minutes until all devices are shut down again .
So opening / closing the car several times during storage will noticeable shorten the calculated period .
Furthermore I recognized that the cars battery management system doesn't charge the battery to its
full capacity during normal use . Thats another drawback predicting storage time .
Hence I always charge my battery before I put my car in storage and recharge it every 4 weeks for about 12h
using a 3.6A ctek charger . Works well since 2.5 years .
regards
Ulrich
Old Feb 10, 2016 | 11:18 AM
lsbrodsky's Avatar
Thanks for the quick replies. I found out the hard way that modern cars drain the battery fast when stored, although 2 weeks was never a problem, 3 weeks was. I also found out, the hard way, that storing the key-less entry key within range of the car, as in on the mud room wall, kills the battery over a short time. The car looks for the key and talks to it. I have been told that the newest cars do not do this if locked but I won't find that out since I no longer hang the car keys on that wall.
What I want to avoid is having to leave the battery maintainer plugged in while I am away on a trip. I had a Battery Tender brand fry on me once. Popped the circuit breaker and did not hurt the car, but I have used CTEK since then.
Larry
Old Feb 10, 2016 | 01:42 PM
Arne's Avatar
My car has been in winter storage since mid October. It stays locked in a garage with the keys in "safe" distance from the car. I use a CTEK charger every 6 weeks, and it only takes aprox 5-7 hours to get it fully charged again each time.
So no problems what so ever here.
