Info screen diplay wonky
Old Sep 6, 2017 | 08:18 PM
Tally Ho's Avatar
Default Info screen diplay wonky
My info screen display (missed an "s" in the title) has been acting wonky for the past few days. The XM will cut out and the 4 squares of info on the display will reset and then the music will resume. This will happen about every 3-5 minutes sometimes and is extremely annoying. I can also hear a slight pop or crackle when it happens. I'll be taking it to the dealer soon as it is under warranty (2016 F Type R). I was checking in here to see if anyone else has had a similar issue so I can go to the dealer armed with info. Thanks.
Old Sep 7, 2017 | 04:19 AM
jaguny's Avatar
I had some wonky electrical related issues due to faulty grounding wire ( some corrosion). The slight pop and crackle is what sounds similar. In my situation I was getting cutout of radio, and other warnings flashing in and out on dash display. Started with the stereo system and spread. Not sure if this is same as your issue, but maybe?
Old Sep 7, 2017 | 08:43 PM
Tally Ho's Avatar
Very close to the same symptoms. Do you know what ground point caused your issue and where it's located?
