Infotainment screen acting up
Old Nov 27, 2016 | 02:28 PM
lsbrodsky's Avatar
Default Infotainment screen acting up
Twice this weekend my screen has started up with just blurred pastel colors. I can turn the screen off but no other button has any effect. If I shutdown the car, lock it and go through the startup again it is fine. In addition, twice it has started up slower than usual. Anyone else seen this issue? A dealer is never going to fix it if it cannot be repeated, I am afraid.
Larry
Old Nov 27, 2016 | 05:49 PM
Unhingd's Avatar
Larry
Hasn't happened on the Jag, but I did have that happen on the MINI. Happened more frequently when cold and required a screen replacement. You may need to leave the car overnight for them to check it out, or wait for it to get worse...and it will.
Old Nov 27, 2016 | 06:00 PM
lsbrodsky's Avatar
They will get the car overnight in January for trunk weather stripping, maybe I can get lucky.
Larry
Old Nov 28, 2016 | 09:54 AM
another_geek's Avatar
Larry
I used to see this on my old x351 XJL when the battery voltage was low. Charging the battery always cleared it up.
Old Nov 28, 2016 | 11:33 AM
lsbrodsky's Avatar
Thanks but I had just taken the car off of the float maintainer. Voltage should not have been an issue but I will monitor that.
Larry
