Installing soft water/conditioning system in my home...for the Jaguar!
Old Nov 21, 2014 | 08:54 PM
zach05855's Avatar
I have a master blaster as well, if you order the 8hp beware you will need a 20 amp outlet. If you use a 15 amp the fuse will blow after a few minutes.
But the unit works quite well.
Old Nov 21, 2014 | 11:16 PM
WaltB's Avatar
According to the manufacturer it pulls a solid 18 Amps. Even a 20 Amp breaker is too low. Circuit breakers are designed for use up to 80% of their rating and should trip once that is exceeded. Granted with the right conditions, slow spool up, new eqment ect. You may be able to get away with a 20 Amp breaker. Some have reported trips, others not.
I'm going to swap my 20 Amp breaker with a 25 Amp that's properly sized and eliminate any potential trip issues.
Walt
rusty37
Jun 7, 2016 04:43 PM
andys-GR
Sep 16, 2015 07:28 AM
johanasu
Sep 3, 2015 12:39 PM
FLStype
Aug 30, 2015 07:27 PM
nelsonht
Aug 30, 2015 06:01 AM
