Launch control
I have a 16 s awd and now that it’s colder, I’m more inclined to play, the issue is... it’s crap.
i engage the brake, press the gas down and once it crosses ~1,200 rpm it will say launch co trip active.
the issue is that once it hits right past 2k, if I keep it there for what seems like any longer than 1 second, it dumps the rom range down to idle again quickly and the car takes off slower than a snail on a glue surface.
do these cars not have launch co trip like the 2 step cars or my old Porsche?
Is is there a way to make it better?
That's not what he was saying. He was saying don't just floor it, you have to actively hold the RPM properly.
and im saying any rpm above 2,500 won’t work and anything above 2,000 gets disengaged too quickly to hold it anywhere
My assumption is the vehicle is doing that on purpose to protect itself. These cars aren't like the hard launching Porsches and GTRs of the world you might expect. In the higher horsepower R variant; launching off idle is the quickest way to accelerate. Anything beyond that the car torque limits to protect the transmission and you go slower.
Again, it wouldn't do anything. Launching off idle is the quickest way to go. Effectively you already have launch control...
You do that now a days and you'll be buying a new transmission.
+1. That's why they have a clutch delay valve and a dual-mass flywheel on the MT cars. No need for side-stepping with a tuned V6. You can light up the tires at will with the clutch fully engaged.
Originally Posted by PunisherFType
and im saying any rpm above 2,500 wonÂ’t work and anything above 2,000 gets disengaged too quickly to hold it anywhere
I apparently just picked up an 2/16 manufactured '17 R but launch control does not appear to work. Even after following directions in Dynamic mode I never see ANY of the launch messages in the dash no matter how "gently" I push the accelerator down. Have others experienced this issue? I assume a software patch would resolve but don't know where to look in the system to determine which version I currently have loaded
believe only the V6S ever had launch control. The R has enough torque at idle not to require a high rev torque converter stall speed.
Makes sense. I was not paying a lot of attention of the cars in the you tube videos were v8s or not but now that you mention it, they were all v6s. I did see it in the manual but I expect that the manual's are identical for both engines. Just a bit odd that JLR didn't put some type of disclaimer in the fine print of the manual stating that it's only applicable for the v6s
ah-ha!
