Lightweight battery?
Old Oct 31, 2019 | 12:56 PM
watson6505's Avatar
reviving a thread a little over a month old...between the prior RS30 battery and what is being talked about here, I am not sure if many with a MY2014 have chimed in. With there being 2 batteries on the older model years, what is the fitment/model for a 2014??
Old Oct 31, 2019 | 02:59 PM
fuzzysquid's Avatar
FYI, Antigravity has a H8/Group 49 size now, so an exact swap for our cars. $950 is still too dear for me. I can only imagine the price will continue to go down... I hope...
https://antigravitybatteries.com/pro...tive/ag-h8-rs/
Old Oct 31, 2019 | 03:47 PM
Chawumba's Avatar
Unless you are a fan of the start/stop feature, you just ditch the 2nd battery and save more weight. The RS30 I put in was roughly the same weight as the small 2nd battery (15 lbs), so by switching out both I removed about 65 lbs. Although, that was when they cost low $600's, someone says they are $950 now???
Old Oct 31, 2019 | 03:59 PM
watson6505's Avatar
yes, the prior post indicated that this current version is $950, but I am not sure this is the same brand/style as the original RS30. I also dont know if the fitment works or not in the compartment under the hood vs in the trunk.
Old Oct 31, 2019 | 04:11 PM
fuzzysquid's Avatar
The original battery being referred to is the RS30: that was ~$600 but is now $700, is of lower capacity and lighter, and needs custom mounting in our cars. 30 Ah/11.5 lbs
The link I posted above is a new product, a straight swap* in a standard automotive size that fits the F-Type, and is $950. It's 60 Ah / 19 lbs
*At least it is for single battery F-Types. I don't know about the 2-battery models.
Old Oct 31, 2019 | 04:17 PM
watson6505's Avatar
Bummer, I am not sure if anyone has gone Lithium battery for the older Ftypes yet....ANYONE?
Old Oct 31, 2019 | 04:21 PM
watson6505's Avatar
Interestingly enough, the search by vehicle facility on this website has only a single '2014-2017' option when selecting an FType. I'm not sure I trust this without contacting them first unless someone has experience with trying this on an older FType.
Maybe Ill measure my current battery and terminal locations
Old Oct 31, 2019 | 04:27 PM
  #28
Paul champagne's Avatar
Originally Posted by Unhingd
Dave,
New profiles of the same battery have been introduced and this may no longer be the best choice as a better fitting battery might be available.
Are those new models from the same manufacturer?
Old Oct 31, 2019 | 04:37 PM
fuzzysquid's Avatar
Yes they're both Antigravity batteries. The RS30 is still available on the same website linked above, but it's $700. I think the $600 price was from a reseller on ebay.
Old Oct 31, 2019 | 08:54 PM
  #30
Thanks, I'll check it out
Old Oct 31, 2019 | 08:56 PM
  #31
Unhingd's Avatar
Yes, I’ll be switching to this battery when the RS-30 fails in about 15 years.
Old Nov 2, 2019 | 05:13 PM
  #32
Paul_59's Avatar
Banned
Originally Posted by DJS
I believe this is the OEM Varta battery...
https://www.dropbox.com/s/5tvrtsxpyl...5D852.pdf?dl=0
I see prices of around $600, though I haven’t looked much. Wonder what the dealer would charge, though I don’t know if they’d bother with the OEM battery.
Yes, a generic H8 AGM would be less.
Must be a lot more expensive in your location.
£179 is US $230 at today's exchange rate
Old Jun 8, 2020 | 12:28 PM
  #33
jahummer's Avatar
Has anyone tried their ATX30 880CCA @ $400 or ATX20HD 900CCA also @ $400 both just under 6 pounds?
Old Jun 8, 2020 | 01:48 PM
  #34
F-Type-Type's Avatar
I've installed the Liteblox LB26XX two years ago, saving approx. 58 pounds (including the weight reduction for the OEM battery tray/holder being repaced with a carbon plate holding the battery), in my 206MY V6S. Has worked like a gem, never had a need to trickle charge, not even during the 5 months winter break where the car is in storage. Start-stop luckily disappeared after installing the Liteblox battery. Installation was very straightforward. Now with the gym closed due to lockdown the old and heavy battery came in handy for use as a kettlebell :-)
Old Jun 8, 2020 | 09:23 PM
  #35
Unhingd's Avatar
The ATX30RS is the successor battery to the RS-30 that I am currently using. Has never failed me even in sub-zero temps without using a battery tender. As mentioned, the ECO stop/start feature won’t work when these lithium batteries are installed. (No real loss).
Old Jun 9, 2020 | 05:22 AM
  #36
DJS's Avatar
DJS
Thought these were more like $700, so I got a $199 AGM at Autozone. For $400, would have gotten one. Next time...
Old Jun 9, 2020 | 10:46 AM
  #37
fuzzysquid's Avatar
I was surprised by the price too, so I looked into it last night. The $400 battery referred to is the ATX-30, with 880 cranking amps and 32 Amp Hours equiv.
The successor to their original RS-30 (1200CA/30Ah) that some folks here have, is the ATX30-HD and is $560. It's 970CA/48Ah.
Both are sold as motorcycle batteries, the HD also as automotive, and both require custom mounting to our cars.
Their direct replacement automotive battery is still $950 and has 1800 CA/60Ah. I think our OEM batteries are around 950CA.
Old Jun 9, 2020 | 01:34 PM
  #38
jahummer's Avatar
I don't care about form factor, I just want to know if it works. I see they also have an ATX20-RS 680CA for $300 weighs less than 4 pounds. If I can save over an additional 50 pounds in weight, it would be worth it
Old Jun 9, 2020 | 08:59 PM
  #39
Unhingd's Avatar
The RS 30 has had more than enough cranking power for the F type. Even though taller than the OEM battery, the OEM tie-down hardware will secure the battery without modification.
Old Jun 10, 2020 | 03:08 AM
  #40
fuzzysquid's Avatar
...I should certainly hope so, given that it has a significantly higher cranking amp rating than the oem battery.
