Longer Wheel Studs -- What are the options?
Old Aug 6, 2019 | 09:23 AM
Jaggyx's Avatar
Default Longer Wheel Studs -- What are the options?
Hi all,
As the thread states, are there options out there for longer wheel studs? Either something aftermarket or OEM?
The only info I can find about our studs is below:
M12-1.50 Serrated Wheel Stud - 13.25mm Knurl, 51.63mm Length
Thanks in advance.
Old Aug 7, 2019 | 09:44 AM
Jaggyx's Avatar
Bumping this. I did an extensive search and could not find anything exact.
According to what I've been able to find online the OE studs are: https://www.dormanproducts.com/p-243...20Lug%2520Stud
And the closest I've been able to find is: https://arp-bolts.com/kits/arpkit-de...hp?RecordID=78
Swapping studs is certainly possible, just a time consuming, and you may need a shop to slightly bore out the hub hole just a tad.
Old Aug 7, 2019 | 09:52 AM
Mahjik's Avatar
I don't know the size/pitch of the OEM studs, but ARP is "the" way to go when wanting to install longer studs.
Old Aug 7, 2019 | 09:53 AM
Jaggyx's Avatar
So I hear.
Apparently, specs are: M12-1.50 Serrated Wheel Stud - 13.25mm Knurl, 51.63mm Length
sherbercars
Dec 1, 2014 09:27 AM
MNXType
Aug 12, 2014 04:56 PM
Jagman 999
Apr 6, 2014 12:16 PM
j_bond
Mar 20, 2011 06:41 PM
adam12hicks
Feb 10, 2009 04:17 PM
