Master Blaster on a Large Vehicle
Old May 16, 2016 | 12:59 PM
swajames's Avatar
Foosh, if you have problems with water spots have you tried something like the CR Spotless system? I have one, and it works. I have the high output DIC-20 and it works as advertised. You wash the vehicle as normal and rinse with the filtered water. Even on a dark car it will dry without spotting without any towel dry. It's not cheap, but it does work.
Water Systems - Products
Old May 16, 2016 | 01:16 PM
Foosh's Avatar
Thanks. I am on well water, but I do have very expensive dual-tank, water softener system plumbed into the house. It uses resin with a saltwater backwash to clean the resin after so many gallons, but I don't think it deionizes.
I probably would have been better off spending the money on this than on the Master Blaster, but I'll probably look into this. It would be nice to wash that coach and not worry about drying it.
Old May 16, 2016 | 03:37 PM
Nati's Avatar
Foosh, just out of curiosity are you sure that both motors were operable and you didn't just get a lemon with 50% power?
Old May 16, 2016 | 03:47 PM
Foosh's Avatar
Both motors are working fine. I said it was OK, but not a time-saver at all. Moreover, it's probably only worthwhile it for a small car. It would be a futile exercise on that big bus, and wasn't that great on my SUV.
Old May 17, 2016 | 09:50 PM
WaltB's Avatar
I Have the Master Blaster as well as the CR Spotless system and love the combination. I use it on all the cars however having a good coat of wax and working the water beads from high to low is best.
Interestingly my MB pull 19 Amps and was blowing my 15A circuit breaker so I had an electrician buddy install a 30A. (A little overkill but I wanted good protection) Remember that circuit breakers are only rated for 75% of their listing so even a 20A circuit is too low for the MB.
Walt
Old May 18, 2016 | 10:49 AM
Schwabe's Avatar
my experience would say no. It works fantastic on my Jags as they are quartzes and water just beads all the way to the edge of a panel and blows off. On my Golf R which is only sealed the water does not stay beaded and you have to blow dry each panel maybe 10 inches wide with the nozzle so you have to be pretty close would not work on such a large vehicle.
Old May 18, 2016 | 11:02 AM
Foosh's Avatar
Yes, I absolutely agree that it will be useless on my coach, but OK for my F-Type. Thanks.
Old May 18, 2016 | 11:26 AM
  #28
Queen and Country's Avatar
Foosh,
You can increase its power by 10x.
Apply ceramic coating to the coach- water will fly off it.
Old May 18, 2016 | 11:40 AM
Nati's Avatar
Originally Posted by Queen and Country
Foosh,
That would be like $5 grand for a vehicle that big. It was $1200 for my car. Not sure there's good return on investment there.
Old May 18, 2016 | 11:43 AM
  #30
Foosh's Avatar
Thanks, I may look into that if I can find a mobile operation that does that. I don't think any of the conventional detail shops will have a large enough garage, but I do.
Old May 18, 2016 | 11:47 AM
  #31
Foosh's Avatar
I think it would likely be a lot more than that. There is 8X-10X the painted surface area of an F-Type. On the other hand, we're talking about a nearly $500K vehicle.
If it were sitting outside like most of these things do all the time, it would probably be worth it. However, this one lives inside a climate-controlled barn when it's not on the road.
Old May 18, 2016 | 11:55 AM
  #32
Blowing the rape whistle. Its a total farce. You can do that coach for $150 in materials and 1 day of time.
If anyone is interested, PM I will share where to get it at cost. There is 90% margin on this racket.
Old May 18, 2016 | 11:58 AM
  #33
You dont need a detail shop. They do, otherwise they would never separate you from your money.
Its one of the simplest things to do. There is no skill or tools required.
All you need is a day where it doesn't rain.
Old May 18, 2016 | 12:02 PM
  #34
Foosh's Avatar
Sent you a PM. I don't even need a day without rain, since I can do it in air-conditioned comfort inside. I'm all ears about the application process.
Old May 18, 2016 | 12:10 PM
  #35
Nati's Avatar
Except you can't buy the pro stuff unless you're an authorized reseller. The retail direct to consumer products are not the same and tend to require more frequent applications.
Old May 18, 2016 | 12:31 PM
  #36
You can already see the scam then.
Its not as magical as you think. My shop would be one of those "professional" users. (we use it in a different application) There is an insignificant difference in durability. Besides its all the same Si02.
Old May 18, 2016 | 12:47 PM
  #37
Schwabe's Avatar
Dan Zagami from paint correction by associates has done RVs before
https://www.facebook.com/PaintCorrec...iated/?fref=ts
you can tell him Dominic sent you, he does all my cars, not sure this will get you a discount though ...
Old May 18, 2016 | 12:49 PM
  #38
Foosh's Avatar
Default Sonax Polymer Shield
Has anyone ever used this stuff? It's ridiculously easy to apply, and my F-Type still beads up like crazy after 6 months. As far as ingredients, it only says it contains Silicone.
I also applied it to my Jeep this past weekend, and it lays down quite a shine.
Old May 18, 2016 | 01:08 PM
  #39
Si02 is also silicone- just nano silicone and more hydrophobic. Dunt it feel good to be phobic about something in this day and age.
Old May 18, 2016 | 01:12 PM
  #40
This sits on top of the paint and washes away if you use strong enough detergent.
Option 1 I sent you in the PM bonds with the paint
The stuff like Cquartz has a acrylic resin base that the nanosilicone is mixed with, which keeps it stuck to the paint for the longest.
