Part Number ID Needed!
Old Jan 21, 2025 | 01:40 AM
WhiteTardis's Avatar
Default Part Number ID Needed!
I guess the years of my size 12 shoe and 6'3 frame while getting in and out finally caused the weatherstrip and retaining clips on the driverside rocker panel to fail. Upon inspection, it appears that some of the weatherstrip retaining clips were missing from the factory..which I'm not surprised. I scoured the F-TYPE parts catalogue and could not find this clip let alone the part number. If I order a new weatherstrip, that won't guarantee new clips will come with it. Any help on getting the part number for the clip?
I found generic ones on Amazon and eBay, but can't confirm the proper size needed.
I need the clips holding part number #3 on the diagram
Old Jan 21, 2025 | 03:27 AM
OzXFR's Avatar
I needed some of those clips a few years ago when I fitted illuminated tread/sill plates and I broke a few of the original clips when removing that sill rubber.
I still have the packet with some in it and searching the number on the packet brings up this Amazon listing:
https://www.amazon.com.au/Mtsooning-.../dp/B07BQLSYK4
Amazon AU I know but I can't get around that!
Anyway they worked perfectly although from memory they are not exactly the same size as the originals, I think they are a little bigger and more robust than the originals.
The number on the packet which for some reason does not show on the web page is SZ100130053386RK.
Edit - that number does show on the web page, I just needed to keep scrolling down!
Edit 2 - it's all coming back to me - I now remember finding heaps of listings for these types of clips so I grabbed an OEM clip and measured it all around then compared the measurements with those showing on the various listings, and these were the closest match. The only real difference was they are a mm or two longer which should rarely if ever be a problem.
Old Jan 21, 2025 | 12:53 PM
Thanks! I copied and pasted the product description on the US Amazon page and have some on the way!
Old Feb 26, 2025 | 04:13 AM
OzXFR's Avatar
Did you ever get the clips and if so did they do the job?
Old Feb 26, 2025 | 04:31 PM
Valerie Stabenow's Avatar
Default May not have been you....
While still under warranty my 2017 had a similar weatherstrip issue. Passenger/right side, but up closer to where the door hinges, not an area that you would think would be hit with feet. Torn weatherstrip and missing 'clip'. Hope what you ordered worked out!!
Old Feb 27, 2025 | 12:01 PM
They sure did. I used 3M automotive double sided tape in conjunction to the clips!
kr98664
Jun 11, 2024 10:07 AM
2020mike
May 26, 2024 06:14 PM
SirJohn
Mar 31, 2022 09:41 PM
wutend666
Jul 19, 2017 08:55 AM
Donna
Oct 2, 2014 04:10 AM
