A pillar fuse box access
I had no trouble hard wiring my detector using a mirror tap, however it turns out I have the infrared reflective windshield, rendering said detector completely useless. I trust you have a car earlier than MY17 when this became standard, and otherwise not installed as an option?
I think there was supposed to be a gap for toll tags.
I ran my dashcam wiring down the driver side A pillar (and yes, you can pop the end cap off the dash when the door is open to get better access) and into the fuse box in the driver side.
If you have a spare dextrous technical five year old to crawl in there and plug things in it makes life easier (much as Victorian folks used to send them up chimneys) otherwise you are going to have to push the seat back as far as it goes and prepare to contort - a headlamp is advisable to be able to illuminate the fuse box but i predict there may be Much Cursing in the Footwell.
Taking it from the mirror with a mirror tap would probably be easier but I already had the fuse tap left over from the XFR installation to reuse. Such is the hair shirt we wear when recycling.
That spot works for toll stickers, but it's impossible to mount a radar detector such that it can "see" out of that location.
